Dell M15 R4 bios motherboard GDR51 LA-K741P
  • zaraky77
    • Sep 2025
    • france
    I've a laptop Alienware M15 R4 motherboard GDR51 LA-K741P with rtx3080
    sn: BD6N9C3
    I've setup a long time ago an Admin and a system password. I can run / install OS with the system password but unfortunately i've forgot the admin password so now i can't update my bios. (it asked the admin psw for instal)
    I've contact the Dell support for the Admin password in bios and the asked me the system id /challenge password but it won't show up the windows in bios just says you've fail 3 times system restart.
    They gave me a code 38DCEE5F to reset but it won't work. I've try to reset hit by tape the psw in the admin setup and valid with ctrl + enter and i also try ctrl + enter enter and it's not working.
    I've read on the forum that the password may in the the ec and not the eeprom. If i buy a ch346A and dump the GIGADEVICE 25R127DSIG and reflash it with a stock bios will this erase my password?
    Or is there a someone can generate maybe another mastercode. thanks
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • capoplays
    Help with BIOS update on Dell G15 5515 after chip replacement
    by capoplays
    Hey everyone,
    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
    When I check the BIOS using the F12 menu Flash...
    10-24-2025, 06:53 AM
  • Akhlz001
    by Akhlz001
    09-20-2025, 07:15 PM
  • jhanra
    by jhanra
    11-02-2024, 04:19 AM
