Asus G713QM bios
  • Lovro25
    • Jan 2023
    • 21
    • Croatia
    Asus G713QM bios
    Hello, can someone please fix this bios? The laptop turns on but shows no picture.
    Model: G713QM
    SN: M4NRKD015526171
  • hoaca388
    Badcaps
    • Jan 2022
    • 12354
    Model: G713QM
    SN: M4NRKD015526171
    G713QM
    • Carlos Simbaña
      • Jun 2024
      • 45
      • Ecuador
      Hello, please I need help with this bios, the laptop turns on and has video, but after a few minutes It frezees, I appreciate the help.
      Asus Model: G713QM-R596
      Motherboard Number: G533-6050A3250203-MB-A01(A1)
      Serial Number: M8NRKD02388133B
      AMD RYZEN 9 5000 SERIES
        SMDFlea commented
        Editing a comment
        Post moved to G713QM thread topic.
    • m1ch43lzm
      • Mar 2019
      • 976
      • Peru
      Check temperatures, also check the heatsink, i think this model uses liquid metal on the CPU, you may have a dry spot there, careful not to spill it on the board
      Try, BIOS extracted from ASUS website with serial/win key inserted
      G713QM
      Bios ver 331
      DMI C1000-C8FFF
      • paulrbf
        • Aug 2023
        • 10
        As title states looking for a bios bin file for this chip.
        The chip is a Winbond 74m12jwsiq.
        Upon doing further research i have found that most people reprogramming this chip use revelprog but since that's not compatible with a CH341a, people were suggesting using the W25Q128FW [1.8V option with asprogrammer and neoprogrammer as thats what it intially detects the chip as. They also claim that this method works.
          • 22012
          Type the laptop serial number, full name and model, motherboard model, etc.
          post the contents of the bios chip even if it is corrupted..
          read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
          • paulrbf
            • Aug 2023
            • 10
            Model Number - G713QM-MB91
            SN- M8NRKD02358133f
            Mother board - G533-6050A3250203-MB-A01
            As for the bios chip, It seems to be working fine as far as i can tell but the issue is the Laptop Is bios password protected so I'm trying to flash a new bios to remove the password. Ill include my bios file if that helps.
            • m1ch43lzm
              • Mar 2019
              • 976
              • Peru
              SN- M8NRKD02358133f
              Pass
              Code:
              Raptors123
              • paulrbf
                • Aug 2023
                • 10
                Originally posted by m1ch43lzm
                Pass
                Code:
                Raptors123
                Thanks for that and it worked. The issue i have now is there was an admin pass and a user pass. The one you sent was the admin that i removed but now the user password has taken over and is locking me lot again as the Admin pass does not work any more
                I was able to get into the bios once and removed the admin password but couldn't remove the user pass. Upon restarting the laptop i am now locked out again and the admin password does not work anymore.
                • peste
                  • 13678
                  • ROMANIA
                  try...
                  1111
                  • paulrbf
                    • Aug 2023
                    • 10
                    Originally posted by peste
                    try...
                    1111
                    Perfect. That worked. Thanks for the help. Another project complete.
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • grimacelord
                      by grimacelord
                      07-10-2025, 02:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • Newmultifail
                      Asus g750jx Bios turns off after 30 minutes
                      by Newmultifail
                      I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again?
                      I should mention that the bios update did not help.
                      backup i sn...
                      I have a problem with the asus g750jx, it shuts down exactly every 30 minutes. There is no overheating and the like, it works perfectly for half an hour. it turns off both in bios and in windows. My guess is that the bios is the problem, would anyone like to take a look and try to fix this bios so I can flash it again? I
                      12-19-2024, 03:41 PM
