dell mini 1018 bios needed
  • ranjanlaptop
    • Dec 2013
    • 207
    • india
    dell mini 1018 PIM10 LA-6501P bios needed please upload
  • Ramee
    • Jul 2014
    • 218
    • Israel
    Re: dell mini 1018 bios needed
    What is the problem of this mini, any picture?
    • ranjanlaptop
      • Dec 2013
      • 207
      • india
      laptop is dead. 5v alw & 3v alw missing. change ic still same.
      • dj_ricoh
        • 2073
        • uk
        does it work with a charged battery?
        • ranjanlaptop
          • Dec 2013
          • 207
          • india
          not working with battery
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            How will the reloading the bios help? Is it a 12v bios chip? if its 5v and you have no five volts
            • dj_ricoh
              • 2073
              • uk
              kinda!
              charging ic must be powered up then it will supply the voltage!
              • boss juben
                • Oct 2016
                • 37
                • philippines
                pls send a clean bios thanks
                • mohammed mohan
                  • Nov 2017
                  • 210
                  • F12
                  ok
                  Mohammed Mohan
                  • Aravindashamal
                    • Jun 2023
                    • Sri lanka
                    i need la-6501p bios bin file
                    • mohammed mohan
                      • Nov 2017
                      • 210
                      • F12
                      thanks
                      Mohammed Mohan
                      • soso technician
                        • Nov 2019
                        • 67
                        • iran
                        inspiron mini 1018
                        PIM10 LA-6501P
                        2010-07-26
                        REV:2.0
                        old rar is extracted dump bios from mainboard and its ok...edited rar is last bios released by dell and edited that by hex editor...both files are ok.
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                        • capoplays
                          Help with BIOS update on Dell G15 5515 after chip replacement
                          by capoplays
                          Hey everyone,
                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                          When I check the BIOS using the F12 menu Flash...
                          10-24-2025, 06:53 AM
                        • Akhlz001
                          by Akhlz001
                          09-20-2025, 07:15 PM
                        • 417731
                          BIOS needed for Dell Vostro 3405
                          by 417731
                          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                          Model: Dell Vostro 3405
                          Tag:F0B1YF3
                          CPU:Ryzen 3500U
                          Thanks in advance
                          07-06-2025, 06:48 PM
