Request BIOS dump for ASUS FA617NS
  • kcp0085
    • May 2025
    Aloha, I'm trying to recover my ASUS TUF Gaming A16 (FA617NS-A16.R77600)
    I have the CH341A programmer and can flash the BIOS chip directly. I need a verified full .bin dump (2MB or full SPI region) for this specific model.
    Specs:
    - ASUS TUF FA617NS-A16
    - CPU: AMD Ryzen 7
    - BIOS chip: Winbond W25Q16JVSIQ (2MB)
    If anyone has a full dump or can share from a working unit, it would be hugely appreciated.
    Thanks in advance!
  • danito
    • Jun 2016
    • 1076
    • Romania
    Specs:
    - CPU: AMD Ryzen 7
    Thanks in advance!​
    post the original bios of the laptop even if it is corrupted,the motherboard model, etc.
    • DozNaka
      • Jul 2025
      • Trinidad & Tobago
      I have the 7700S variant of this laptop (FA617NT)
      That chip you just stated only contains the VBIOS for the 7600S which you can obtain from the techpowerup website (backup first before flashing)
      The actual bios chip is circled in red and may require a different connector for your programmer
      I cannot provide the BIOS file for this laptop as I have a different model
      • Septian
        • Jan 2024
        • 19
        • Indonesia
        Please my brother fix this bios file, there is no display after failed bios update
        MODEL : FA617
        FA167NS-R7X2J6T-O
        SN: R4NRKD03279315H
        CN: 0DE8
        KODE BOARD
        FA617-PMV-PGT
        6050A3460701-MB-A04
        2022-11-25
        • m1ch43lzm
          • Mar 2019
          • 807
          • Peru
          BIOS extracted from ASUS website with serial/win key inserted
          FA617NS
          S/N: R4NRKD03279315H
          Bios ver. 419
          DMI 1050000h-1057FFFh
          • Septian
            • Jan 2024
            • 19
            • Indonesia
            FA617NS
            Bios ver. 419
            Thanks a lot bro, this file is working
            • RCCBUBC
              • Sep 2025
              • 7
              • CANADA
              Need help with the bios file.
              Keyboard lights up but black screen.
              FA617NSR-AS71-CA
              Serial: S7NRKD008787286
              • m1ch43lzm
                • Mar 2019
                • 807
                • Peru
                Originally posted by RCCBUBC
                FA617NSR-AS71-CA
                Try reading the BIOS chip again, if using a clip lower SPI clock frequency to 4-8MHz, cannot extract DMI data from your bad backup...
                • RCCBUBC
                  • Sep 2025
                  • 7
                  • CANADA
                  Unfortunately, the bios is overwritten already. I made another backup which is attached here. Please let me know if this one worked. If not could we download based on the serial number?
                  Thanks again for your help!
                  • m1ch43lzm
                    • Mar 2019
                    • 807
                    • Peru
                    Try BIOS extracted from ASUS website
                    FA617NSR
                    Make sure you lower SPI clock speed when writing if using clip, otherwise you will have errors
                    • RCCBUBC
                      • Sep 2025
                      • 7
                      • CANADA
                      it worked like a charm! Thank you so much!!!!
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • DynaxSC
                        by DynaxSC
                        06-14-2024, 03:49 PM
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • ArkzG
                        [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                        by ArkzG
                        Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                        What I currently have available:
                        - Model: FA506NF (2021)
                        - BIOS chip: GD25LQ16 (16Mbit/2MB)
                        - Tools: CH341A programmer ready to use
                        Does anyone have either a clean 2MB .bin dump of this model,...
                        09-26-2025, 09:34 PM
