Lenovo ideapad 3 15ARH05 corrupt bios settings
  • techcraze
    • Nov 2019
    • 13
    • Netherlands
    Hello good day. Long story short. i unlocked the bios using SREP and switched the setting "Special display features Enable/Disable HybridGraphics" from "HybridGraphics" to "disabled"
    this has bricked the laptop. it does not boot on internal or external display...
    i have tried flashing known good roms from both lenovo and other forums and reflashed it to the chip.
    but still no boot. the device turns on and cpu heat's up. but no post/boot.
    I have attached the dumped corrupt bios.
    The original serial is PF2KJR1J and bios version was FCCN21WW.
    Board has the following info printed on it "GY535/GY536" with board ID of NM-D191 / NM-D19 Rev 1.0
  • techcraze
    • Nov 2019
    • 13
    • Netherlands
    System is AMD and with 1650 (TI? not sure) dgpu.
    system worked perfectly fine before i screwed up that single bios setting.
    i read on a unrelated forum that recovery is impossible for these modern AMD systems if bios setting caused a brick??
    • hardware1
      • Sep 2021
      • 2949
      • N/A
      Here is your new file, it's a virgin BIOS from Lenovo with your DMI and Windows Key.
      all donations are welcome,
      • techcraze
        • Nov 2019
        • 13
        • Netherlands
        thanks for the reply! will test and report back asap. have desoldered and resolderd this chip like 4 times already testing different biosses LOL. (also got a bunch of spare SPI chips to test incase i fried the OG)
        Board uses 1.8v chip. my flasher is 1.8v confirmed.
        hoping this is finally it.
        • techcraze
          • Nov 2019
          • 13
          • Netherlands
          Working perfectly with your bios.
          I think it seems that these boards will NOT permit older biosses once upgraded before. even if reflashed using a known good old build.
          • hardware1
            • Sep 2021
            • 2949
            • N/A
            That's great. I don't know where did you get a known good BIOS, but anyway it could be not suitable for your device.
            • techcraze
              • Nov 2019
              • 13
              • Netherlands
              i have tried the biosses from this thread on badcaps
              • AquaMan Ua
                by AquaMan Ua
                05-17-2025, 09:40 AM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • Bloodhoundje
                HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                by Bloodhoundje
                I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                I have desoldered the bios chip (GigaDevice...
                03-16-2024, 03:12 PM
              • TripTop
                Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                by TripTop
                Hi
                i have dell latitude E7270 with following symptoms:
                - takes long time to restart.
                - sometimes powers on and then off
                - sometimes while working it just dies,
                From googling online bios clean could possible resolve this?
                i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                I reinstall...
                09-09-2024, 02:05 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
