Lenovo Gaming 3 15ARH05 NM-D191 BIOS please
  • sopik78
    • Nov 2013
    • 522
    • Czech Republic
    Dear friends,
    please share BIOS dump of Lenovo Gaming 3 15ARH05, NM-D191, GY535/GY536
    Old one is attached
    Thanks a lot!
  • BootLoader1
    • Aug 2020
    • 72
    • Poland
    Re: Lenovo Gaming 3 15ARH05 BIOS please
    Try FCCN16WW + DMI + Win Key
    • sopik78
      • Nov 2013
      • 522
      • Czech Republic
      Thanks, but unfortunately doesn't work. The old one is corrupted, should be 16MB.
        • 25724
        try this one .
        • mikailcoban
          mikailcoban commented
          Editing a comment
          dear friend bios is working but on screen no led .. windows open we know by sound but this bios there is no light .. please check it
      • sopik78
        • Nov 2013
        • 522
        • Czech Republic
        Thanks a lot, working!
        • kokokoko
          mastercare
          • Mar 2018
          • egypt
          Re: Lenovo Gaming 3 15ARH05 NM-D191 BIOS please
          hello guys need bios for this model
          GY75M GY75N
          NM-D282 REV: 1.0
          • ddbbdd44
            • Mar 2022
            • turkey
            SAS Programmer rev :3,9 available, this programmer does not have IT8227E-128 compatible driver, I need to supply this driver
            motherboard model GY535/GY536 NM-D191 REV: 1.0 ec bios me plase
            • mikailcoban
              • Aug 2014
              • 76
              • turkey
              their friend we have same laptop .. I look bios but bios cip was different someone change wrong cip.. I change and write bios .. laptop started but no display ..
              but they do something Uv3 chip..
              VBIOS: 25LQ80CTIG (UV3, 1,8VCC)
              I must change and write this .. have someone has this cip...
              • mrkmpn
                • Apr 2022
                • 74
                ideapad Gaming 3-15ARH05 Cannot edit DMI
                I could never get a consistent dump from this board (NM-D191, GY535/GY536) but I was running out of things to try so I decided to download and extract the latest bios from lenovo support and flashed it. I was not concerned about not being able to copy the DMI info, because I frequently replace Lenovo board under warranty and use the uOne tool to add all of the information, and was able to get the Windows key from the drive.
                The laptop is now consistantly booting properly, but When I try to use uone tool or lvar to edit serial number, etc... I get an error "SMI Interface not ready". Could this be because something is missing from the bios i flashed, or indicate there is something else wrong with the board?
                Without a good dump in which I could edit, and copy this section I'm unsure how to get past this problem.
                • peste
                  • 16527
                  • ROMANIA
                  Re: ideapad Gaming 3-15ARH05 Cannot edit DMI
                  read..
                  try the bios from post #4.. enter your bios and the bios from post #4 in the HxD program, and copy the DMI range (75C000-75DFFF) from your bios to bios post #4... (select the range in both bios and copy-paste)..
                  If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
                  It only takes 1 minute:
                  https://www.badcaps.net/settings/subscriptions
                  • mrkmpn
                    • Apr 2022
                    • 74
                    Originally posted by peste
                    read..
                    The BIOS from #4 did not work, and the DMI section was actually at 74C000. I found the reason I could not find the section by searching was that the section is apparently encrypted in this BIOS.
                    I found a tool that decrypts the section, so I copied that to the new bios I got from lenovo site, re-encrypted it with the tool, and flashed it. All of the information showed up in bios settings, but still if I tried to use the U1 tool (set uuid for example) as a test, I still got the SMI Interface not ready error.
                    So I checked the BIOS from post #2, and it had the DMI section at same offset. This time I tried copying and pasting the DMI section without decrypting and then reencrypting, and flashed it.
                    The serial number, etc... did not show, but the U1 tool did work with this BIOS. Thank you for the help, I sent a small donation yesterday for this section.
                    • judamex
                      Active Member
                      • Jan 2021
                      • 215
                      • Mexico
                      • BIOS, Learn fix motherboards
                      Need this bios or EC please, ryzen 7 with RTX, no power on, all rails ok
                        VIP Moderator
                        • Aug 2018
                        • 4387
                        • Bulgaria 🇧🇬
                        • Gadget & motorcycle addicted
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • judamex
                          Active Member
                          • Jan 2021
                          • 215
                          • Mexico
                          Originally posted by Vesko356
                          Thanks for the correction, I apologize for my post.
                          • khaly
                            • Jan 2015
                            • 22
                            Bios is password protected.
                            Type 82EY
                            SN PF2HD2AW
                            MB is GY535/GY536 NM-D191 rev 1.0
                            I have tried the bios in post #4 https://www.badcaps.net/forum/showthread.php?t=100174 but I got a black screen.I tried a external monitor and it was working .With that bios from post #4 works when I change from discrete to switchable in bios , if I reset the bios for any reason
                            I get a black screen again because the default option is discrete.
                            If anyone can please help me remove the password from the original bios.Thank you
                            • khaly
                              • Jan 2015
                              • 22
                              Extracted from fccn19ww , tested and working.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3750
                                • slovakia
                                • hard-enduro
                                Guys i replaced shorted SIO IT8227E on this board . do i need to flash EC bios? Have it somebody?
                                Type 82EY
                                SN PF22C3VG
                                MB is GY535/GY536 NM-D191 rev 1.0​
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3750
                                  • slovakia
                                  • hard-enduro
                                  Type 82EY
                                  SN PF22C3VG
                                  bump. Any help please
                                  • peste
                                    • 16527
                                    • ROMANIA
                                    Type 82EY
                                    SN PF22C3VG
                                    try this... extracted from the bios from post #16
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3750
                                      • slovakia
                                      • hard-enduro
                                      thank mate, looks like it worked. but previous shop must broke PS_ID circuit, because still dont have charger wattage detection
                                      • Boardview and Schematic Bot
                                        Lenovo IdeaPad Gaming 3 15ARH05 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad Gaming 3 15ARH05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ARH05 boardview and Gaming 3 15ARH05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 10:20 PM
                                      • Remskiy228
                                        BIOS Dump Request — Lenovo ThinkPad P14s Gen 5 Intel (21G2) (21G3)
                                        by Remskiy228
                                        Hello everyone!
                                        I'm looking for a BIOS dump or assistance with BIOS recovery for my Lenovo ThinkPad P14s Gen 5 Intel.
                                        Laptop specifications:
                                        - Model: Lenovo ThinkPad P14s Gen 5 Intel
                                        - Machine Type: 21G2
                                        - CPU: Intel Core Ultra 5 135H
                                        - GPU: NVIDIA RTX 500 Ada Generation
                                        Problem:
                                        My laptop stopped booting after a firmware update through Lenovo Vantage. It powers on but does not POST or display anything.
                                        What I'm looking for:
                                        Either of the following...
                                        Yesterday, 09:48 AM
                                      • Do_Yuri
                                        Lenovo IdeaPad 3 15ADA05 (81W1) — cannot enter BIOS, system always boots in Legacy mode
                                        by Do_Yuri
                                        Hello.
                                        I’m trying to diagnose a Lenovo IdeaPad 3 15ADA05 (Model 81W1).
                                        Hardware
                                        Model: Lenovo IdeaPad 3 15ADA05 (81W1)
                                        BIOS version: E8CN34WW
                                        Internal drive: NVMe SSD (detected normally)
                                        Symptoms
                                        BIOS Setup is almost impossible to enter.
                                        Pressing F2 during power-on usually freezes on the Lenovo logo or is ignored.
                                        The Novo button opens the Novo Menu, but selecting BIOS Setup...
                                        08-01-2026, 01:58 PM
                                      • yellowtiger
                                        Lenovo Slim 7i 14IMH9 - Failed BIOS Update and Stuck in Boot Loop - BIOS Request
                                        by yellowtiger
                                        Hello Everyone,
                                        I have a Lenovo Slim 7i 14IMH9 that got stuck in a boot loop with black screen after a failed BIOS update through Lenovo Vantage.
                                        Here are my laptop details:
                                        - Model: Lenovo Slim 7i 14IMH9
                                        - Serial Number: YX09M0K7
                                        - Machine type: 83D80003US
                                        **Problem:**
                                        About two weeks ago a BIOS update for this laptop failed and the laptop has been stuck in a boot loop with black screen ever since. Now when I press the power button, the keyboard lights come on and the fan starts running. However, the screen remains black. The laptop...
                                        06-14-2026, 11:04 AM
                                      • lucaszmn
                                        by lucaszmn
                                        Problem:
                                        Initial Findings:
                                        • I concluded that the
                                        08-12-2025, 03:01 PM
