hp g62-a022sl bios dump.
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    ok, as almost all the time, i have a friend hp with no screen problem. i see it has a intel i3, and ati gpu. after open it it had lot lot of dust. cleaned it all, cleaned also board with ipa as always. plugged some cable, power on and pc just started telling me it has no wifi and no cmos battery. i turned it off (removing ac power cable instead of powering it off by botton). reassembled and then pc just do nothing on pressing power botton. after try a bios reflash as shown here
    but i think bios rom was too big. now pc start with fan at max speed, but no post. it power off after some times. and when i repower on it keep on but no post and fan stop after a time even if it get hot.
    does anyone got a bios dump ?
    do i need a bios dump from you guys because vendors didnt make them public on their site?
    edit: just pluged in keyboard and caps lock keep blinking. ram coil has 1.5volt.
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: hp g62-a022sl bios dump.
    reballed vga and still the exact same problem :S
    edit: all voltage are present at coil....
    • dj_ricoh
      • 2073
      I only got a g62 amd but you can take it from hp!
      the exe file then go with 7zip and right click on it and chose open archive.
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        tnx for reply. as the attached picture ive gone to hp site, downloaded and extracted. then with a usb programmer, i desoldered bios chip, and flahed like whown in the picture, but somewhere i read that i need a proper bios dump file to program some kind of bios chip, as mine in the image told me it was bigger then 4mb space.
        how ever before doind that pc wont even turn on. now turn on... and after some 20 seconds it tutn off, then on again but no screen. tried a reball of the vga but still nothing.
        • dj_ricoh
          • 2073
          if the file its bigger then its not the same!
          I did a few weeks ago a cq and there still is the post around here.
          nvm I use the file from hp; the only down side is that it got no serial.
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            tnx, as far now pc power on fan and led blink, my bios is ok.
            just i dont hear hard disk spin, so can be the ec chip that need to flash too ?
            • dj_ricoh
              • 2073
              what size do you have on bios?2,4?
              do you got another chip like that with 512kb?
              • dellxps15
                • Feb 2014
                • 1588
                • italy
                bios chip is 4mb. yes it has another rom for ec chip.
                • dj_ricoh
                  • 2073
                  snap you need that to!
                  frak
                  • dellxps15
                    • Feb 2014
                    • 1588
                    • italy
                    ok, flashed ec file (i suppose is for power light indicator and some staff like that maybe already working) and laptop do exactly the same
                    strange thing is that if i remove ram... it do still the same.
                    • dj_ricoh
                      • 2073
                      can you post a pic without heatsink?
                      • dellxps15
                        • Feb 2014
                        • 1588
                        • italy
                        the not good positioned resistor up vga chip is now ok.
                        the last thing to do is try a sb reball.
                        the strange thing is that notebook started ok once. after cleaning with ipa and mount it again wont start annymore.
                        maybe some bad solder joint....
                        • dj_ricoh
                          • 2073
                          you know what I did with mine?
                          I got it from ebay with 29£ it said no display. ofc I did power up.
                          I let run for 20 min hten I shutdown and start it back instant
                          guess what? it started hp logo bla bla bla .
                          block the vent system and let run for 15 min or do soft reflow
                          maybe maybe
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            i read that too. and when pc start (with fan at max speed) it shut down after about 20-30 seconds. then it power on again with fan at max speed too and after 1 min or so, fan turn off but pc still on and start getting hot.
                            someone told that must be some solder joint behind ram and cpu...
                            • dj_ricoh
                              • 2073
                              cook the board then
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                doing that....... just let's see if it works. my question is ... i reballed vga... maybe that wasnt the problem
                                https://www.youtube.com/watch?v=IgH98o3cu0A
                                here some talk about bad solder on mainboard, some that is vga problem... but if it's vga problem then my reball has gone bad ?
                                edit: tryed that toast and didnt work. reballing for the second time gpu...
                                • dellxps15
                                  • Feb 2014
                                  • 1588
                                  • italy
                                  edit2: ok did a new reball of the gpu and still the same....
                                  hit quote insted of edit...
                                  • dellxps15
                                    • Feb 2014
                                    • 1588
                                    • italy
                                    in the diagram, on page 30 i see installed and not installed discrete gpu. the one with not discrete has different resistor respect the dedicated one. could i try disable dedicated gpu ?
                                    • dj_ricoh
                                      • 2073
                                      your testing the board with only the heatsink on and with vga cable to monitor?
                                      or internal lcd of the notebook?
                                      check both maybe maybe
                                      got this problem like 5 days ago and reflow for nothing because a stupid lcd cable.
                                      and a idiot friend told me to reflow a Compaq because he said No display.
                                      I did and it turn out to be a bad memory .
                                      • dellxps15
                                        • Feb 2014
                                        • 1588
                                        • italy
                                        i tested with vga cable but the same, caps lock was blinking continuosly. as the unique said im going to reball the northbridge. i removed it yesterday, but then i spot that i need 0.35mm balls that i dont have (have 0.45, 0.5, 0.6 and 0.76). just bought them from uk
                                        PS: just did a try with solder paste, but cant do so much with it
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
                                        • DynaxSC
                                          Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                                          by DynaxSC
                                          I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                                          It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                                          I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                                          11-06-2022, 05:22 PM
