ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
  • Technodoc
    • Aug 2007
    • 10
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere here on the forum)
    Here is however my problem : the bios file that is saved, is 32.768 kB
    The bios file I downloaded from the Asus website (version 331) is after extracting 38.016 kB in size
    I have to extract the bios from this updatefile but am not sure how to proceed...
    Is there someone who can shine some light on this ?? have attached both bios files
    Thanks in advance,
    Frans​
    • 21641
    Read https://www.badcaps.net/forum/troubl...before-posting ,and type the laptop serial number please.
    • Technodoc
      • Aug 2007
      • 10
      Sorry....s/nr R5NRKD037485206
      CN : RWNJ
      MFD : 2023-05
      • ruslan657
        • Mar 2016
        • 74
        • Azerbaijan
        hey friends, hope all u fine
        need help bios
        G634J-PMV-VGT
        6050A3441302-MB-A01
        ASUS G634JY-NM035
        S/N R5NRKD00594622B
        • hoaca388
          Badcaps
          • Jan 2022
          • 12257
          need help bios
          G634J-PMV-VGT
          6050A3441302-MB-A01
          ASUS G634JY-NM035
          S/N R5NRKD00594622B
          G634JY
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • LtCdrData
            ASUS Rog Strix 6050A3441302-MB-A01 BIOS
            by LtCdrData
            I'm trying to flash the bios chip but all the files on the asus website end in a 3 digit bios number. I'm not sure how to convert/trim/extract from these files to a file I can load with AsProgrammer to write to the chip.
            ASUS Rog Strix Scar G18 G834JY-XS97
            latest version 331 or oldest 317 would be great. thanks!
            https://rog.asus.com/us/laptops/rog-...helpdesk_bios/
            09-16-2025, 06:13 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
