Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
ASUS Rog Strix 6050A3441302-MB-A01 BIOS
  • LtCdrData
    LtCdrData
    • Aug 2025
    I'm trying to flash the bios chip but all the files on the asus website end in a 3 digit bios number. I'm not sure how to convert/trim/extract from these files to a file I can load with AsProgrammer to write to the chip.
    ASUS Rog Strix Scar G18 G834JY-XS97
    latest version 331 or oldest 317 would be great. thanks!
    https://rog.asus.com/us/laptops/rog-...helpdesk_bios/
  • hoaca388
    Badcaps
    • Jan 2022
    • 12664
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • LtCdrData
      LtCdrData
      • Aug 2025
      Sorry, I was trying to find an edit for my main post, but I will add the relevant data here...
      I was unable to get anywhere with BIOS guides, methods, resources and tools because ... one of the steps is to use ME Analyzer to get proper firmware file - ME Analyzer comes up with CSE ME 16.1.32.2418 which is not available in the repository.
      Machine model number: G8347JY-XS97
      Serial number: R8NRKD008963339
      Board model number: G634J-PMV-VGT (6050A3441302-MB-A01)
      No display. Laptop turns on for 1 minute then reboots (and repeats). No noise except fans. Attempting to flash BIOS in hopes it resolves the issue.
      dump file split because of upload limits
      • peste
        • 14706
        • ROMANIA
        The bios must be in ".bin" format and archived with winrar or 7zip...
        The bios chip must be unsoldered from the board before writing or reading..
        do not use the clip, you may have errors..if you do not have anything to unsolder it with,
        solder wires between the programmer and the bios chip..
        you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
        • LtCdrData
          LtCdrData
          • Aug 2025
          I have soldered wires to the chip. Are you saying that my current connection to the chip is bad? I've been using AsProgrammer and it has been detecting and working with the chip fine, as far as I can tell.
          I have attached the zipped .bin file
          • hoaca388
            Badcaps
            • Jan 2022
            • 12664
            ROG Strix SCAR 18 (2023) G834YJ
            • LtCdrData
              LtCdrData
              • Aug 2025
              Originally posted by hoaca388
              Thank you! It didn't fix my issue. Now the laptop turns on, and stays on (power light stays lit, RGB keyboard cycles through colors), but still no display. CPU/GPU do not get hot. No fans spin. Thoughts?
              • ruslan657
                • Mar 2016
                • 76
                • Azerbaijan
                hey friends, hope all u fine
                need help bios
                G634J-PMV-VGT
                6050A3441302-MB-A01
                ASUS G634JY-NM035
                S/N R5NRKD00594622B
                • techkid
                  • Nov 2016
                  • 35
                  • philippines
                  hello can you help me to rebuild this bios i dont know if this bios is original because already reprogram by other tech
                  ROG Strix SCAR 18 (2023) G814JZ
                  G634J-PMV-VGT
                  6050A3441302-MB-A01
                  g814jz-G18-I94080
                  SERIAL: R6NRKD02553123B
                  THANKS FOR HELP MATE APRECIATE IT
                  no display issue
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12664
                    G634J-PMV-VGT
                    6050A3441302-MB-A01
                    g814jz-G18-I94080
                    no display issue
                    Your device is G814JZ. Fault backup, read chip again.
                    • techkid
                      • Nov 2016
                      • 35
                      • philippines
                      i reprogram already brother
                      but this laptop already refprogram by other technician
                      i buy it somewhere in my place
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12664
                        Come here :
                        https://www.badcaps.net/forum/troubl...78#post3804778
                        • ronaldopdias
                          ASUS ROG Strix B660-I Gaming WiFi – BIOS dump vs ASUS CAP size mismatch, need corruption check, please.
                          by ronaldopdias
                          I’m troubleshooting an ASUS ROG Strix B660-I Gaming WiFi motherboard and I’m a bit stuck at the BIOS level. What I’ve tried so far
                          • Attempted to flash the BIOS using the USB BIOS FlashBack (Q-Flash) port with a properly formatted FAT32 USB drive.
                          • BIOS file downloaded directly from the official ASUS support page.
                          • Followed the exact FlashBack procedure (correct port, renamed file, standby power only).
                          Issue:
                          The FlashBack LED does not blink at all — no activity whatsoever. Further investigation
                          Because FlashBack didn’t work, I:
                          • Removed the BIOS SPI IC from
                          02-04-2026, 03:16 AM
                        • razor_amd
                          by razor_amd
                          12-15-2020, 07:07 PM
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • Technodoc
                          ASUS G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                          by Technodoc
                          Asus laptop G614JZ-N3012W Rog Strix with i7
                          Mainboard G634J-PMV-VGT
                          6050A3441302-MB-A01
                          2023-02-10
                          Power button works okay....power light goes on
                          Red "bottom" leds go on
                          Charging led works
                          Fans do not spin, capslock key does nothing, screen stays black
                          I would like to program the bios again, to rule out a corrupted bios.
                          However I run into a size error
                          The bios chip is a Winbond 25R256JVEN
                          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                          02-24-2025, 04:46 AM
