ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
  • Technodoc
    • Aug 2007
    • 10
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere here on the forum)
    Here is however my problem : the bios file that is saved, is 32.768 kB
    The bios file I downloaded from the Asus website (version 331) is after extracting 38.016 kB in size
    I have to extract the bios from this updatefile but am not sure how to proceed...
    Is there someone who can shine some light on this ?? have attached both bios files
    Thanks in advance,
    Frans​
    • 21523
    Read https://www.badcaps.net/forum/troubl...before-posting ,and type the laptop serial number please.
    • Technodoc
      • Aug 2007
      • 10
      Sorry....s/nr R5NRKD037485206
      CN : RWNJ
      MFD : 2023-05
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • LtCdrData
        ASUS Rog Strix Scar G18 G834JY-XS97 BIOS
        by LtCdrData
        I'm trying to flash the bios chip but all the files on the asus website end in a 3 digit bios number. I'm not sure how to convert/trim/extract from these files to a file I can load with AsProgrammer to write to the chip.
        latest version 331 or oldest 317 would be great. thanks!
        https://rog.asus.com/us/laptops/rog-...helpdesk_bios/
        09-16-2025, 06:13 PM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
