Dell XPS 15 7590 BIOS unlock
    can someone update this BIN and remove bios password and computrace?
    ST: GRTJM53
    Board: LA-H331P
    Originally posted by digitaldisorder View Post
    can someone update this BIN and remove bios password?
    ST: GRTJM53
    Board: LA-H331P
    just the password. computrace is not enabled. thanks!
      Would it not be easier to flash a new, clean BIOS? I am not sure if you did this dump within an OS, IC or removed from the board but assuming you can flash it, download a BIOS for your laptop.
        yes, i just don't know where to add the serial number, though
          Take a look at this guide: https://www.badcaps.net/forum/troubl...rces-and-tools it will probably help you more than I could
            ST: GRTJM53
            Board: LA-H331P
            your bios backup is corrupted, read again bios chipset
              posted wrong place, removing from here. Thanks peste for helping
              • peste
                peste commented
                Editing a comment
                post merged..
              post S/T..full name and model, motherboard model, post the original contents of the bios chip..etc.
                Model - Dell XPS 7590
                Service Tag - 9D6V8Y2
                Bios chip - GD25B256DYIG
                Hi, the laptop which had a failed bios update and not refuses to boot. Pressing power button, the keyboard lights up for a second and that's it. There is no fan spin, no signs of boot.
                The laptop was running windows and linux dual-boot, Before this happened, there was another bios update, that was giving issues as well, laptop went starting up started doing auto bios recovery almost every time, flashing an older version of bios via bios recovery seemed to fix that issue but the auto recovery issue came back in a week. And with another failed update, it refuses to boot.
                I have attached the bios below.
                Any help is much appreciated.
                  Hello try ....
                    Originally posted by Markus1741 View Post
                    Hello try ....
                    Its perfect, works great. Thank you so much. Would this also fix the auto bios recovery that was triggering on laptop boot before , or is that related to some separate issue.
                      dell XPS 15 7590
                      motherboard EDP51 EDB51 LA-H331P REV 1.0
                      sn 2G51M63
                      black srean
                        Hello try ....
                          Hello try ....
                          This message related to the BIOS appears every time the system is started.
                          The keyboard and touchpad do not work in the BIOS, but they function correctly in the operating system. Click image for larger version
                            Hello try ....
                            Auto Recovery triggered during boot and didnt properly flash, now top row of keyboard does not work from q to p . Have to fiddle a lot to make it turn on, charger disconnect and reconnect multiple times. Crashes automatically. I have made a new backup of bios. Attached below. Please help.
                            Thank you
                              Thank you
                              Hi, try and feedback
                                The laptop boots fine - specific keys still do not work - namely - qweruiop . It autoflashed and updated to 1.27 . i disabled uefi bios updates in bios and flashed your firmware again. Rebooted the laptop and Firmware Update started again and failed and windows turned on, restarted again and firmware update started again(updaing system bios with bios guard), bios updated again and windows loads up, keyboard was working fine before these bios issues, so its not hardware issue . I also tested the keyboard in the bios after i have just flashed the file you provided and the specified keys dont work.
                                Thanks again for your help
                                  Hi just checking back if possible to fix the keyboard issue, for some reasons even with the somewhat working bios the keyboard keys qwer uiop arent working, even after doing recovery and update using ctrl + esc recovery..
                                    Hello try ....
                                    Hi markus, the bios gives issue on reboots, I flashed the bios again, turned off auto recovery, used it on windows for couple of hours. it rebooted once perfectly fine, but on second reboot , the bios crashed and showed 3 orange 6 white led blinking. I read the bios again and am attaching it here.
                                      Originally posted by piszpunta View Post
                                      dell XPS 15 7590
                                      sn 2G51M63
                                      black srean
                                      try.
