Dell XPS 15 7590 BIOS unlock
  • Markus1741
    • Sep 2020
    • 1000
    • N/A
    Originally posted by gagan
    Hi markus, the bios gives issue on reboots, I flashed the bios again, turned off auto recovery, used it on windows for couple of hours. it rebooted once perfectly fine, but on second reboot , the bios crashed and showed 3 orange 6 white led blinking. I read the bios again and am attaching it here.
    I had the same problem once with a Dell 5590.
    I also recreated the BIOS with 3 and 6 flashing and then everything worked normally.
    Days later the same 3 and 6 flashes again, I then discovered that the Gigadivece IC itself was defective.
    Then I used a Winbond and everything was fine.
    I would use a new chip or another chip for you.
    • digitaldisorder
      digitaldisorder
      • Jun 2022
      • 21
      Originally posted by volinakis
      your bios backup is corrupted, read again bios chipset
      oops, realized i pulled from wrong chip. i believe i have the right one now... if someone can remove just the BIOS password please.
      Model - Dell XPS 7590
      Service Tag - GRTJM53
      Bios chip - GD25B256
      Board - LA-H331P
      • volinakis
        • Jan 2021
        • 3231
        • N/A
        Board - LA-H331P
        try
        please support this forum
        • digitaldisorder
          digitaldisorder
          • Jun 2022
          • 21
          try
          hrm, the laptop boots to Dell Security Manager. is it possible to remove?
          • volinakis
            • Jan 2021
            • 3231
            • N/A
            post photo.
            • digitaldisorder
              digitaldisorder
              • Jun 2022
              • 21
              post photo.
              thanks!
              • volinakis
                • Jan 2021
                • 3231
                • N/A
                #27
                thanks!
                pass is:
                q91[22xz6N3U22L2
                use US keyboard and after type password press and hold left Ctrl and press Enter twice.
                If you read Bios Guide of this forum you can do it yourself ...
                https://www.badcaps.net/forum/troubl...30#post1622430
                • digitaldisorder
                  digitaldisorder
                  • Jun 2022
                  • 21
                  pass is:
                  q91[22xz6N3U22L2
                  success! can finally use again after 2 years of it just sitting in the drawer. bookmarked! thanks for your help and the link!
                  • gagan
                    • Nov 2022
                    • 27
                    Hi , would this chip work as replacement
                    Winbond W25Q256JVEIQ
                    • Markus1741
                      • Sep 2020
                      • 1000
                      • N/A
                      #30
                      Of course it's a 3 volt chip
                      • gagan
                        • Nov 2022
                        • 27
                        Hi Markus , so its been 24 hours i have changed the chip and flashed the bios that you cleaned for me. There seems to be zero issues. I have disabled UEFI updates as a precaution. Thank you so much for all the help you offered.
                        Also for anyone else who's having bios auto-recovery issues, you should try replacing the bios chip.
                        I will keep using the laptop and if there are any issues, i ll post an update here.
                        Thank you so so much, Markus. You are awesome.
                        • yasin
                          • Jan 2022
                          • 21
                          • iran
                          #32
                          hi plz remove password bios
                          precision 5540
                          service tag> jzgpk63
                          p.m la-h331p rev1.0
                            • 24137
                            precision 5540
                            p.m la-h331p rev1.0
                            Off topic, different model in the thread title. Post your request in the Precision 5540 topic -> https://www.badcaps.net/forum/troubl...sion-5540-bios
                            • serseb
                              • Aug 2024
                              • 31
                              I have a Dell XPS 7590, for which I need to remove the BIOS password. Can anyone please help me with this? The details about the laptop:
                              Dell XPS 7590
                              ST: D4B1M63
                              MB: couldn't find it (is it on the keyboard side?). I presume it's a LA-H331P
                              Administrative password removal needed
                              Thanks a lot!
                              • Blaze Tech
                                Learner
                                • 324
                                • Ghana
                                • Repairs
                                #35
                                Dell XPS 7590
                                ST: D4B1M63
                                Thanks a lot!
                                TRY
                                • serseb
                                  • Aug 2024
                                  • 31
                                  Originally posted by Blaze Tech
                                  TRY
                                  Didn't remove the password but did start in factory mode. I noticed that only two bytes were changed in the dump. It's supposed to be like that?
                                  • serseb
                                    • Aug 2024
                                    • 31
                                    I managed to get a valid password from here: https://bios-pw.org/ , so not needed any more. Thanks!
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • Tesla
                                      Dell XPS-15 (9520) Mostly Bricked after common BIOS-Firmware upgrade - Full Repair Log
                                      by Tesla
                                      I have a Dell XPS-15 (9520) with the LA-L402P motherboard. It seems to have bricked itself after a common BIOS-Firmware upgrade. Now, it just shows BIOS screen for a few seconds before turning-itself back Off (and doesn't seem to be fully Posting). I've done these many times before with no problems.
                                      I was hoping to please have my own-thread to work-through this (hopefully successful) repair as a whole. Apart from the possible need to have a BIOS-dump fixed-up, I have a feeling I'm going to have other questions. This includes using my new XGecu-T76 for the first time (should be here...
                                      03-19-2026, 07:51 PM
                                    • Akhlz001
                                      by Akhlz001
                                      09-20-2025, 07:15 PM
                                    • TopPop
                                      Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                      by TopPop
                                      Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                      I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                      12-14-2025, 09:40 PM
                                    • Godfather79
                                      Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SouthPeak15) bios
                                      by Godfather79
                                      Hello everyone in the community
                                      Dear Sir,
                                      I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                      Problem details:
                                      * Model: Dell Latitude 5520.
                                      * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                      * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                      * Service Tag: (Enter your actual Service Tag from the laptop here)
                                      * BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                      11-08-2025, 10:04 AM
