Lenovo T480s 20L8 bios Dump
  • sweemann
    • Nov 2024
    • 9
    i managed to remove the supervisor PW of my Lenovo T480s with autopatcher works like a charm.
    The problem i have now is that i cant disable Secure boot. I tried many other dumps from Badcaps they do work but after flash there is the ME Version Line empty
    and the bios time is up to 70 seconds. Is there any possibility that some can mod my dump to disable secure boot ?
    Thank you in advance.
  • hardware1
    • Sep 2021
    • 2948
    • N/A
    Do you mean the Secure Boot option is in gray and you can't change it? Have you tried to set a supervisor password then try to change that option?
    all donations are welcome,
    • sweemann
      • Nov 2024
      • 9
      Yes it is grayed out. I tried really everything setting password doesnt work for me. I dont know why.
      • Stefan Steff
        • Mar 2024
        • 371
        • Romania
        I never had such problem with this bios file...
        • sweemann
          • Nov 2024
          • 9
          Really you made my day. I dont know why but your uploaded dump seems to fit perfect. Please tell me what did you do ? Did you anything about ME Clearing ? Or is it simply one out of stock ?
          As i said i patched my original dump with autopatcher because i forgot the supervisor password after that secure boot was disabled and couldnt be enabled. Every single dump i tried ihave some issues.
          As i said the orig dum secure Boot loocked other dumps needed more than 60 seconds bios time and so on. I would be very happy to hear what did you do to fix my dump ?
          • Stefan Steff
            • Mar 2024
            • 371
            • Romania
            I'm glad to hear it's working.
            This bios file isn't your fixed dump, it's a dump I "cooked" for my use and because Lenovo keeps serial, model, pass and other things in EC memory this dump works without errors on any T480s.
            In your case Secure Boot greyed out it's a sign of bad bios region and 60 s boot time it's a sign of corrupted ME region.
            So as a conclusion, it's easier to write this stock bios than cleaning ME and writing a new bios region to a faulty bios file...
            • sweemann
              • Nov 2024
              • 9
              yes my investigation without knowing anything at the beginning leaded me to this conclusion thats something from with ME region. I also tried to reprogram with analyzer but i think that was a way to high for me.
              Thank you very much.
              • Kaar3l
                • 24
                • Estonia
                Hello!
                I bought a dead T480s.
                At first when I tried to start it it did start with no picture and run for 15 sec and then shutdown. Pushed power button again and same cycle.
                What I have tried:
                1) Tried another bios from here. It did start take 0,4A and stay that way with black screen. Seemed that it doesn't do restarts.
                2) Desoldered onboard ram resistors. Didn't have any effect.
                Now it flashes 3 times light when power is inserted and is dead. Power button does nothing. Power button works when checking with multimeter and also 3V comes. When button pressed the 3v is pulled to 0v so power button is ok.
                TYPE 20L7-001SMX
                S/N PC-0YGNZY
                18/10
                I made dump from the original bios. Could you clean it?
                • peste
                  peste commented
                  Editing a comment
                  post merged..
              • AHmad_Salal
                Need BIOS Dump/ROM for Lenovo Thinkstation p500
                by AHmad_Salal
                Hello all,
                I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                11-28-2023, 05:28 AM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • hyperwood
                [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                by hyperwood
                I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                āœ… What I need:
                • A working 2MB BIOS dump
                • Matching NM-E471 Rev. 2.0, e.g. JY575
                06-25-2025, 02:28 PM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
