Dell 8FC8 Patcher
  • Aldo Fabiano
    • Mar 2025
    • ITALIA
    i'm sorry but i can't use the PATCHER. I have a Dell Vostro 3510, service tag 25XF4W3-8FC8 could you tell me the password that i need to enter with the admin block?
    There is no OS on the pc and i can't install it untill i unlock the notebook.
    Thanks a lot
    • hoaca388
      Badcaps
      • Jan 2022
      • 11713
      Thanks a lot
      Why ?
      • Reyvin trujillo gomez
        • Mar 2025
        • 10
        • México
        Can someone help me with the absolute, I can't disable it
        • pineapple
          • Mar 2013
          • 17
          Greetings, and thanks so much for all the effort you've put forth into this software. I have a Dell Precision 7540 8FC8 laptop on my bench.
          Here's the issue I am having... When I run the program on my dumped file, I get an error code in red containing the phrase "intel signature". After peeking into the source code, I can see that this mentions it could be a corrupted dump or otherwise not a BIOS hex. I have dumped the chip a half dozen times, and diffing them together shows they are all identical. This is the only flash chip I can find on the motherboard and the hex does contain some plaintext strings such as the model number of the laptop. I tried running as admin, etc.
          I bet I'm the idiot here, but here's hoping someone can point out something I am overlooking.
          • rex98
            • Feb 2023
            • 1275
            • Mandaue CEBU, Philippines
            post your problem here in this thread and your original dump and don't forget the service tag. . https://www.badcaps.net/forum/troubl...7540-dump-file
            • pineapple
              • Mar 2013
              • 17
              Thank you very much for your reply, my friend. As I work with this specific laptop, I find it seems to be that one certain model that has decided to be so difficult with which to work. Thankfully I purchased it for next to nothing...
              I will head over to that thread and see what happens!
              • Darren Hibbert
                • 102
                Hi.
                Am about to use the patcher software on my Dell 5440. I opened it up to use my CH-341A on the bios chip but noticed it had 2. My CH-341A only has the connector size Click image for larger version
ID:	3610785 for 1 of the chips. Which chip in the picture do I use to read and write to?
                Many thanks.
                  • 20807
                  Originally posted by Darren Hibbert
                  Hi.
                  Am about to use the patcher software on my Dell 5440. I opened it up to use my CH-341A on the bios chip but noticed it had 2. My CH-341A only has the connector size for 1 of the chips. Which chip in the picture do I use to read and write to?
                  Many thanks.
                  If the suffix is 8FC8 it will be in the SOP8 chip.
                  • Darren Hibbert
                    • 102
                    All done. The patcher worked perfectly 😊😊
                    • MOHDZGSM
                      • Feb 2023
                      • 11
                      • zoui ouled rechache
                      #30
                      Hello, please, I have the same Dell 5440 computer. If you can help me with the method and the chip that you worked on. DXVSW14-8FC8
                      • peste
                        • Dec 2016
                        • 12748
                        • ROMANIA
                        #31
                        post S/T, full name and model, motherboard model, etc.
                        post the contents of the bios chip even if it is corrupted..
                        read the forum rules..
                        https://www.badcaps.net/forum/troubl...ore-posting​
                        • MOHDZGSM
                          • Feb 2023
                          • 11
                          #32
                          Hello, please, I have the same Dell 5440 computer. If you can help me with the method and the chip that you worked on. Click image for larger version
                            • 20807
                            2 ,the SOP8 chip
                            • Ali_Khan
                              • Dec 2023
                              • 12
                              • Egypt
                              #34
                              because it's standalone you don't need to install the dotnet-runtime-6.0.29-win-x86 to run the program. its with the exe
                              Or it contains hacking tools that work in background ?!!
                              • MOHDZGSM
                                • Feb 2023
                                • 11
                                #35
                                Dell 5440 Click image for larger version
                                • MOHDZGSM
                                  • Feb 2023
                                  • 11
                                  #36
                                  DELL 5440 unlock please bios
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11713
                                    #37
                                    This is just the ME area.
                                    • rex98
                                      • Feb 2023
                                      • 1275
                                      #38
                                      you want the runtime dependent there you go. check it all you want its only 490kb, but first install the dot net runtime for the app to run or if you still have trust isues download the runtime in microsoft website.
                                      • MOHDZGSM
                                        • Feb 2023
                                        • 11
                                        #39
                                        Please, who can remove the password? bios dell 5440
                                        • peste
                                          • Dec 2016
                                          • 12748
                                          • ROMANIA
                                          #40
                                            Dell 8FC8 Bios Password Patcher
                                            by SMDFlea
                                              DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                              The unlock scripts given here are for personal use only, ie. you accidentally set a password on
                                              your own machine,you forgot the password you set a long time ago or you mistyped the password
                                              when setting it and cannot get in again.
                                              DISCLAIMER: THE SCRIPTS
                                            11-03-2023, 06:02 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • dr_crx
                                            Dell 7740 Bios locked J3JSD43-8FC8
                                            by dr_crx
                                            Hello i need help please
                                            i have DELL 7740 ST: J3JSD43-8FC8
                                            i tried to read bios bit i think it is wrong because the size of the file is around 1mb
                                            anyone can help to show its location on motherboard please.
                                            i attached the results file the IC i read is : winbond 25q80dvsig
                                            i don't know if its the needed bios or another bios on the motherboard.
                                            thank you in advanced for your help...
                                            07-11-2025, 12:22 AM
                                          • al_b0sni
                                            Dell Optiplex 5000 8fc8 with chip W25Q128JVSN
                                            by al_b0sni
                                            Hey, i bought a Dell Optiplex 5000 8fc8 with chip W25Q128JVSN.
                                            I also used the CH341A programmer but my usb cable (i didnt attach it directly into the pc, i used a cable between) was corrupted. So i made a dump. Then i removed the password but unfortunately the dump had a loose contact so it was corrupted. And i've also overwrited the chip and now i dont have any dump anymore.
                                            Can someone help me? I am stuck since hours and i cannot find any bin file anywhere.
                                            I tried to extract the EXE for BIOS installation from dell and also the rcv file but i didn't manage to do that....
                                            06-18-2025, 03:42 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
