Asus G713PI bios
  • trunguntilyou
    • Aug 2022
    • 362
    • Vietnam
    Asus G713PI bios
    help me ! need bios G713Pi
    sn:R2NRKD032737084
  • shiyab
    • Sep 2023
    • 1611
    • india
    sn:R2NRKD032737084
    hi try
    • trunguntilyou
      • Aug 2022
      • 362
      • Vietnam
      Originally posted by shiyab
      hi try
      The bios worked perfectly,, thanks a lot
      • shiyab
        • Sep 2023
        • 1611
        • india
        OK good CAN YOU SHARE ITS BOARD NUMBER PLEASE???
        • trunguntilyou
          • Aug 2022
          • 362
          • Vietnam
          6050A3468901-MB-A01
          https://www.badcaps.net/forum/troubl...sus-rog-g713pv
          the same
          • shiyab
            • Sep 2023
            • 1611
            • india
            OK thank you
            • futadmytro
              • Aug 2020
              • 65
              • Сполучені Штати
              Hello
              i have same problem - no post after bios update
              asus G713PI
              i flash bios fron post#13 G713PV model ad laptop boot but nvidia driver did not install
              i write dmi from my bios but no luck
              can anybody help?
              g713p-mb-vgt
              6050a3468901-mb-a01
              2022-12-02
              g713pi-xs96
              R2NRKD01956808D
                SMDFlea commented
                Editing a comment
                Post moved to G713PI thread topic.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12330
              Originally posted by futadmytro
              Hello
              asus G713PI
              can anybody help?
              g713p-mb-vgt
              6050a3468901-mb-a01
              2022-12-02
              g713pi-xs96
              R2NRKD01956808D
              G713PI
              ​https://www.badcaps.net/donate
              • hoanglonglaptop
                • Mar 2020
                • 4
                • Russia
                sn:R2NRKD032737084
                có bios hãng - asus acer dell chuẩn hãng out ra
                has genuine bios - asus acer dell genuine output
                in English please..
                • Kim_555
                  PRO.
                  • Jan 2014
                  • 7
                  • Now I'm in Chicago
                  Hi, please help me. I got a laptop for repair -
                  Asus G713PI-DS94
                  CN:ZJG4
                  G513R-MV-HSB
                  6050A3348206-MB-A01
                  The BIOS was flashed with a non-original one, and there is no start. I found and downloaded the original BIOS from the official site by serial number. - cut off the part for the bootloader - no luck. Found and downloaded several BIOSes from Vinafix - on one there was a reaction to the button. The voltage on the board increased - but the screen was black, USB detection was not carried out by the board.
                  Maybe someone has or had such a laptop in work and you can share the dump. Thanks.
                  • shiyab
                    • Sep 2023
                    • 1611
                    • india
                    Asus G713PI-DS94
                    CN:ZJG4
                    G513R-MV-HSB
                    6050A3348206-MB-A01
                    post backup bios and snid
                    • Kim_555
                      PRO.
                      • Jan 2014
                      • 7
                      Click image for larger version  Name:	IMG_6319.jpg Views:	0 Size:	3.42 MB ID:	3718100 Click image for larger version  Name:	IMG_6318.jpg Views:	0 Size:	2.88 MB ID:	3718099
                      Thanks for reply,
                      R6NRKD008350246
                      Unfortunately, there is no original BIOS. It is lost, the laptop came into my hands after another repairman
                      I tried searching by serial number on the Asus website, cut off the excess (what is for the flasher utility) - there is no reaction to the button, the power does not rise, the battery does not charge.
                      I attached the file that starts the laptop, but in it, the search only finds the model 513
                      • shiyab
                        • Sep 2023
                        • 1611
                        • india
                        Thanks for reply,
                        R6NRKD008350246
                        hi try
                        • Kim_555
                          PRO.
                          • Jan 2014
                          • 7
                          Hello, thank you very much, but unfortunately there is no result.
                          There were difficulties with flashing the multicontroller, I had to unsolder it and flash it forcibly through the qfp128 socket
                          after connecting the power supply - with this BIOS autostart, the data packet is read and then - black screen. memory power supply (for example) does not rise.
                          • m1ch43lzm
                            • Mar 2019
                            • 942
                            • Peru
                            Post a clear picture of the QR code near the USB ports on the motherboard
                            I'm guessing this motherboard doesn't match a G713PI (2023) but a G513R/G713R (2022) variant
                            • Kim_555
                              PRO.
                              • Jan 2014
                              • 7
                              Click image for larger version  Name:	IMG_6336.jpg Views:	0 Size:	507.3 KB ID:	3718654 Click image for larger version  Name:	IMG_6335.jpg Views:	0 Size:	1.86 MB ID:	3718655
                              Thanks, here are photos
                              Most likely, this is some kind of "transitional" model, although the case indicates that it is 2023. The history of this laptop is also unknown, I suspect that there could be other problems with the processor, but someone tried to flash the BIOS, and did not save the original. I tried to search in the dump - which was sewn to me - the serial number of the laptop was unfortunately not there....
                              but what is known for sure is that the behavior of the motherboard is different for different dumps
                              • m1ch43lzm
                                • Mar 2019
                                • 942
                                • Peru
                                Code:
                                C7E38MC02UY,R835NRKD000VEVMB,G713RC,60NR08F0-MB2060,600,E89C2580228F
                                Try with G713RC BIOS
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • grimacelord
                                  by grimacelord
                                  07-10-2025, 02:52 PM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • throwaway327
                                  by throwaway327
                                  Model No: RC72LA
                                  Serial No: SBNVKD001014459
                                  06-18-2025, 05:52 PM
                                • lrouw84
                                  by lrouw84
                                  Hi there,
                                  01-28-2023, 01:31 PM
