Panasonic CF-SZ6 Bios unlock
  • thoaitam
    • Jan 2022
    • 11
    • VietNam
    Dear all, I have a panasonic laptop with message "Insert SIM correctly to boot system". I tried with the SIM but it cannot bot to OS.
    Could you please help me? I attack the bios bellow. Thank alot.
  • peste
    • Dec 2016
    • 13661
    • ROMANIA
    post the S/N, post the original content of the bios chip, the motherboard model,the full name and model of the laptop,etc.
    • thoaitam
      • Jan 2022
      • 11
      • VietNam
      I attached the original bios chip, the S/N is 9LKSC45051, motherboard model is Cf-SZ6, model is Panasonic CF-SZ6.
      Thanks you.
      • minhdigital
        • Nov 2022
        • 765
        • Vietnam
        Thanks you.
        Send to you, try !!!
        • thoaitam
          • Jan 2022
          • 11
          • VietNam
          Dear anh Minh,
          I tried but it not work for me, the "Insert simcard...." message still remain.
          Cảm ơn anh.
          • minhdigital
            • Nov 2022
            • 765
            • Vietnam
            Dear anh Minh,
            Cảm ơn anh.
            Try again !!
            • Martin1981
              • Jan 2025
              • 5
              • Japan
              any chance i can get passwords removed thanks.
              panasonic cf-sz6
              Model:CF-SZ6RFQVS
              SN:9GKSC02672
                SMDFlea commented
                Editing a comment
                Post moved to cf-sz6 topic.
            • shiyab
              • Sep 2023
              • 1626
              • india
              panasonic cf-sz6
              Model:CF-SZ6RFQVS
              SN:9GKSC02672
              hi try
              • Martin1981
                • Jan 2025
                • 5
                • Japan
                Originally posted by shiyab
                hi try
                Thank you very much. I also encountered the "Insert simcard...." problem. Could you tell me which field I should modify?
                • Martin1981
                  • Jan 2025
                  • 5
                  • Japan
                  Try again !!
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1356
                    • France
                    Is this message present before removing the password?
                    I don't know this model or this error?
                    a module is interesting and checks the status of the simcard : EmergencyMode
                    InvalidPasswordCount SelfDefenseInvoked Is Stolen
                    • Martin1981
                      • Jan 2025
                      • 5
                      • Japan
                      Yes, “Insert SIM card correctly to boot system”.
                      panasonic cf-sz6
                      Model:CF-SZ6RFQVS
                      SN:9GKSC02672​
                      • minhdigital
                        • Nov 2022
                        • 765
                        • Vietnam
                        panasonic cf-sz6
                        Model:CF-SZ6RFQVS
                        SN:9GKSC02672​
                        Try
                        • Martin1981
                          • Jan 2025
                          • 5
                          • Japan
                          It works fine.
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • aa10aa10
                            Panasonic Toughbook CF-33 mk1 BIOS repair
                            by aa10aa10
                            Good day,
                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                            01-21-2025, 06:13 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • dvt1989
                            Unlock bios Panasonic CF-RZ6
                            by dvt1989
                            Pls help me unlock password bios Panasonic CF-RZ6....
                            04-08-2025, 08:55 PM
