asus a43sj power on problem - Bios
  • alihomee
    • Dec 2012
    • 1585
    • malaysia
    when press power button it turns on and then goes off and then turns on again.it do three times like this and then gives display after that runs normal.i flash bios from asus website but same. any one solve this issue with a good working bios file.........the number on mobo is k43sv
  • alihomee
    • Dec 2012
    • 1585
    • malaysia
    Re: asus a43sj power on problem
    any ideas
    • atsio
      • Oct 2013
      • 819
      • Greece
      You should use a post - debug card to see where bios stops (if it starts at all posting).
      I would also heat gently (up to 200 degrees) PCH and GPU to see if it makes any difference.
      • alihomee
        • Dec 2012
        • 1585
        • malaysia
        i already try with latest virsion ...........same
        • alihomee
          • Dec 2012
          • 1585
          • malaysia
          actually i have tried 4 bioses all same result.and one more thing that after the display comes it would not boot but i tried with different hdd then it boots up and goes to windows normal.the laptops own hdd i tried with different laptop and it also works that means that hdd is fine.but if i put in this laptop it would not boot and also can not go to bios.............i think that very difficult to solve.......
          • atsio
            • Oct 2013
            • 819
            • Greece
            It might seem to work but if smart is enabled on BIOS, it will maybe not allow you to boot. Check HDD thoroughly.
            • alihomee
              • Dec 2012
              • 1585
              • malaysia
              hdd is working fine it can boot with different laptop. and there is no smart option in the bios which can disable
              • dj_ricoh
                • 2073
                try with a usb keyboard. a few days ago i had a similar problem with a F siemens
                • alihomee
                  • Dec 2012
                  • 1585
                  • malaysia
                  tried already with a usb keyboard and without keyboard also
                  • leiangelo5
                    • Apr 2016
                    • Philippines
                    same goes for my k43sj motherboard. and it broke 3 of my HDD. -__-
                    • penhitam
                      • 42
                      • Malaysia
                      same here...6 time on and off..
                      • brixlaptoprepair
                        • Mar 2016
                        • 15
                        • canada
                        Flash bios
                        • muthee254
                          muthe_kenya
                          • Aug 2017
                          • 10
                          • kenya
                          please share your bios files. i have the same issue here. mine keeps rebooting.. no display.
                          • qonma
                            Kuli Solder
                            • Jun 2017
                            • 184
                            • INDONESIA
                            cek the ram, and any device put out
                            • qonma
                              Kuli Solder
                              • Jun 2017
                              • 184
                              • INDONESIA
                              k43sv rev.....?????? if i have am share to you
                              • muthee254
                                muthe_kenya
                                • Aug 2017
                                • 10
                                • kenya
                                mine is k43sv rev 2.2
                                • gitsfarmaz
                                  Professnal tech
                                  • Apr 2017
                                  • 30
                                  • Kenya
                                  try those
                                  • jimore
                                    • Nov 2020
                                    • 179
                                    • mexico
                                    Re: asus a43sj power on problem - Bios
                                    Tested bios frezz from laptop
                                    • razor_amd
                                      by razor_amd
                                      12-15-2020, 07:07 PM
                                    • lucaszmn
                                      by lucaszmn
                                      Problem:
                                      Initial Findings:
                                      • I concluded that the
                                      08-12-2025, 03:01 PM
                                    • jbonavita
                                      by jbonavita
                                      Some issues
                                      Things I tried
                                      04-29-2025, 09:38 PM
                                    • throwaway327
                                      by throwaway327
                                      Model No: RC72LA
                                      Serial No: SBNVKD001014459
                                      06-18-2025, 05:52 PM
                                    • AquaMan Ua
                                      by AquaMan Ua
                                      05-17-2025, 09:40 AM
