when press power button it turns on and then goes off and then turns on again.it do three times like this and then gives display after that runs normal.i flash bios from asus website but same. any one solve this issue with a good working bios file.........the number on mobo is k43sv
asus a43sj power on problem - Bios
Re: asus a43sj power on problem
actually i have tried 4 bioses all same result.and one more thing that after the display comes it would not boot but i tried with different hdd then it boots up and goes to windows normal.the laptops own hdd i tried with different laptop and it also works that means that hdd is fine.but if i put in this laptop it would not boot and also can not go to bios.............i think that very difficult to solve.......Comment
same goes for my k43sj motherboard. and it broke 3 of my HDD. -__-Comment
try thoseComment
Re: asus a43sj power on problem - Bios
Tested bios frezz from laptopAttached FilesComment
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
08-12-2025, 03:01 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
- Loading...
