need help with asus g14 2022 model GA402RJ bios
    • 21944
    Originally posted by VektorR
    Unfortunately there is no possibility to get corrupted BIOS backup since my laptop is with IT technician and the BIOS is corrupted anyway. That's why I asked for full backup of known good BIOS from the same model which someone might have.
    Depending on how badly the bios is corrupted we might just be able to get the serial number and windows key to transfer to a new bios, if you can maka a backup. Do you have a programmer ?
    • VektorR
      • Oct 2024
      • 9
      • New Zealand
      Here is a BIOS backup you asked for. Hopefullty you can fix it and make my Zephyrus running again. Thanks in advance!
      • Bios Cracker
        • Oct 2024
        • 322
        • India
        Try and Update.
        • VektorR
          • Oct 2024
          • 9
          • New Zealand
          Unfortunately no luck . Still the same issue - long delayed startup (turning on) and no backlight. Abscence of schematics means no way to figure out what's wrong and to repair . I even went extra mile for this laptop - ordered an original pre-programmed chip. It didn't help either. Looks like BIOS is not a problem here. Suspect that maybe CPU is on it's way out due to overheating. CPU seem controls almost everything these days...
            • 21944
            Post a picture of the QR code near the ram slot, or scan it yourself and post what it says.
            • tempestekm
              • Nov 2016
              • 7
              • indian
              #26
              Can i get the ec bios of Asus Rog Zephyrus G14 GA402RJ io controller IT5125VG-192 2149-CXO Thanks......
                • 21944
                Post the laptop serial number as text and post your bios and EC backups
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
