Need Bios EC dump for Yoga 7 14ITL5
  • Lubazi
    • Apr 2024
    • 14
    Hello i need bios and ec dump for
    Yoga 7 14ITL5
    S/N: PF253Q07
    Modell: 82BH004XGE
    The two attached BIOS files work but the two USB-C ports do not work and I cannot charge the device.
  • volinakis
    • Jan 2021
    • 2877
    • N/A
    try. Archive.zip is your original bios with clean ME, F5CN64WW.zip is extracted bios from update with your DMI.
    • Lubazi
      • Apr 2024
      • 14
      Thanks for the files, unfortunately it still doesn't work I tested both
      I don't understand, the two Thunderbolt ports work perfectly. Only charging doesn't work
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        check this thread
        https://www.badcaps.net/forum/troubl...-usb-c-problem
        • namcir
          • Dec 2011
          • 4
          • australia
          hi guys can somebody help me is my bios corrupted? i can't update my bios anymore, but my laptop is working and windows working fine. when i try to update my bios there is an error so i attached the screen shot. please help
          • peste
            peste commented
            Editing a comment
            merged post..
        • namcir
          • Dec 2011
          • 4
          • australia
          why merged? btw i already did a clean install of windows and changed drives, still the same
            • 22279
            If you have an SPI bios programmer make a backup and post it here,along with the laptop serial number. If you don`t have a programmer you could try a bios recovery
            You`re not the only one to have the same problem,its happened to others and with different models
            https://forums.lenovo.com/t5/Lenovo-...ls/m-p/5268365
            https://forums.lenovo.com/t5/Lenovo-...or/m-p/5056951
            https://forums.lenovo.com/t5/Lenovo-...or/m-p/5257101
            https://forums.lenovo.com/t5/Lenovo-...ne/m-p/5195704
            Quote:
            I was able to do a downgrade to version F5CN57WW using the Crisis method described here: https://www.reddit.com/r/Lenovo/comm..._14itl05_bios/
            Here is the F5CN57WW firmware if you need it (https://1drv.ms/u/s!AvPnrDOGjsUMgY0S...b0ZBw?e=YfTxcd), I renamed the BIOS.fd file to F5Crisis.bin and it works like a charm.
            End Quote.
            Attached is the F5Crisis.bin ,extract it from the zip folder and read the instructions at the reddit post
            • namcir
              • Dec 2011
              • 4
              • australia
              thanks for the bin. it works, then i updated to the latest firmware and as before i can not access the bios again. because i cannot use the previous bin file i've search for a newer one and recovered again. i think the issue is the sequence, need to install the intel management engine firmware first before updating the bios
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                08-07-2025, 04:54 AM
              • Rdd KEuns
                Lenovo X1 Yoga Gen5 Full Bios chip dump request.
                by Rdd KEuns
                Hello, My lenovo x1 yoga gen5 laptop has been unstable and sometime freezes. After downgrading the bios i was normal for a moment but when back to being unstable.
                If anyone has an working bios please share it.
                Laptop lenovo x1 yoga gen5. serial number PF-2MSZ9Q. Type number 20UC-S2410N. Motherboard model number GX4A0/GY650 NM-C881 Rev1.0. Bios chip GD25B256DYIG...
                03-21-2025, 05:49 AM
