Asus X705UV bios
This topic has been answered.
  • MDSI
    • Apr 2022
    • 28
    • France
    Asus X705UV bios
    Hello.
    I have an Asus X705UV which no longer starts since the last Windows update. I suspect Windows Update of having tried to update the bios and having corrupted it, because currently, I have the charging indicator when I plug in the charger and I have the power indicator when I press the on/off button but nothing more, not even a fan running.
    Could someone check this bios and if it is broken, repair it?
    Sorry in advance, google translate is useful but not perfect. 😂
    Thank you in advance !​ 🙏
  • Answer selected by MDSI at 04-25-2024, 01:12 AM.
    peste
    • Dec 2016
    • 13258
    • ROMANIA
    Originally posted by MDSI
    I tried to follow the guide to flash it myself but I have two problems, the first is that the bios that Asus provides is not in .bin and no way to recover the .bin, the second problem is It says that the original version of my bios is 202 for my motherboard on the label but on the card it is written X705UQ REV2.0.
    Concretely, I can't figure it out.
    I will post the photos of the labels to you, it will certainly be more meaningful for you.
    TY
    Click image for larger version Name:	IMG_20240424_163856.jpg Views:	0 Size:	781.3 KB ID:	3259061
    TRY...
    • MDSI
      • Apr 2022
      • 28
      • France
      TY
      • biosfix_ec
        Banned
        • Apr 2024
        Model bios x705uv
        • hoaca388
          Badcaps
          • Jan 2022
          • 12182
          Serial number ?
          • peste
            • Dec 2016
            • 13258
            • ROMANIA
            TY
            TRY...
            • MDSI
              • Apr 2022
              • 28
              • France
              It's working ! Thank you peste ! 🤘
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • davidebeatrici
                Asus X541UV Windows update KB5063060 deleting BootOrder EFI environment variable? bios fix
                by davidebeatrici
                I had 3 people contact me in a week because Windows suddenly didn't boot:
                As you can see, all 3 are ASUS computers, but I believe the common factor is the BIOS being American Megatrends (AMIBIOS/APTIO).
                The first two recovered just fine after a restart, but the third one didn't and was brought to me. The model is F541UV (X541UV).
                Setup allows to add a boot option manually and the operating system boots just fine from both bootx64.efi and bootmgr.efi. However, there is no way whatsoever to save the option(s): upon a reboot the machine goes straight...
                06-17-2025, 12:59 PM
              • jinki_dadou
                ASUS ExpertCenter D700MD need update bios
                by jinki_dadou
                helle
                in have asus desktop
                model : D700MD-5124000950
                CPU i5 12400
                I wanted to upgrade the processor i7 13700
                when I change the processor show black screen and fan spinning fast
                i ask asus technical support
                the answer : include microcode in the latest update bios
                he give me file 1 update bios
                2 microcode
                2 fils in tha attachments please help me
                ( sorry for my dab english )...
                05-18-2025, 02:20 AM
              • mikeybass
                by mikeybass
                04-23-2025, 04:30 PM
