ASUS F15 TUF Dash FX517ZC-HN114W BIOS
  • caffeinecrazy
    • Apr 2024
    • 4
    • United Kingdom
    Hi All,
    Laptop: ASUS F15 TUF Dash FX517ZC-HN114W
    Context: When I was out the house my partner hard shutdown laptop while BIOS was updating, so my son has no working laptop now. Also as a result I know the BIOS on the chip is messed up so I can’t extract it using the ch341a and use it to perform the method explained on site to modify an update downloaded from the ASUS website to get the BIN to flash.
    If anyone can help with a BIOS BIN/ROM file for this laptop, I would be forever in your debt! Thanks if you can help!
    Assuming it is less than 2MB as the Winbond 25Q16JWNIQ I found on board only has 2MB capacity. The ASUS 317 CAP file appears to be 38 MB…
    • 21649
    You can still backup and post the corrupt bios as it might be repairable.Find another chip, the bios is bigger than 2MB, wrong chip.
    • caffeinecrazy
      • Apr 2024
      • 4
      • United Kingdom
      Ok cheers, I’ll keep looking. Found another flash chip by micronix, thought I’d solved it…nope 8Mbit/1MB…fml
      • Gcs_rma
        Banned
        • Dec 2023
        • 108
        • N/A
        FX517ZC- bios
        • peste
          • Dec 2016
          • 13395
          • ROMANIA
          Originally posted by Gcs_rma
          FX517ZC- bios
          what's with this bios? is it ok? post the name, the model, the model of the board and the base, give more details.. so we know what the problem is..
          • caffeinecrazy
            • Apr 2024
            • 4
            • United Kingdom
            Thanks for your help all but I think this one is beyond me as I cannot get an adequate connection to the chip with a SOIC clip (it's a GD25R256D in aWSON8 package so the pins are mostly underneath). Going to have a break and a think.
            • peste
              • Dec 2016
              • 13395
              • ROMANIA
              remove the chip from the motherboard, put it in the adapter and the adapter in the programmer..
              • TimeRabbit07
                • Feb 2023
                • 9
                Hi All!
                Has anyone had success with any of these BIOS files? I'm looking to flash a new bios to an Asus FX517Z (Note the lack of an "E" on the end), however, its board number is the same DA0NJLMBAE0 so I'm assuming the BIOS files in this thread should work fine.
                Here are all the system's IDs and other numbers:
                Model short: FX517Z
                Model long: FX517ZC-HN114W
                SN: NANRCX01S57842E
                CN: 3SDB 12M
                MFD: 2022-10
                Motherboard model: DA0NJLMBAE0 REV E
                Current problem:
                Nothing happens when the power button is pressed, but the charging light is on. Apparently this behaviour started after a BIOS update, hence why I've jumped almost straight to flashing a new one.
                Also, can I just flash this BIOS file to the chip following the Forum's main tutorial or do I have to also bring across any IDs from the old BIOS; MAC addresses etc? I'm a bit of a novice to BIOS flashing so some guidance would be appreciated!
                  SMDFlea commented
                  Editing a comment
                  Post moved to "FX517ZC-HN114W" topic. Make a backup before you do anything. When you have it post it here
              • TimeRabbit07
                • Feb 2023
                • 9
                Following on from my last post - here's what Neo Programmer has read from the chip (I've read it twice and compared the results, so this should be a good read). Would anyone be kind enough to transfer the DMI information from this old BIOS to the new one - or point me in the direction of a guide on how to do it myself?
                Many thanks!
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Many thanks!
                  Bios Version 315
                  • TimeRabbit07
                    • Feb 2023
                    • 9
                    Originally posted by kalilinux25
                    Bios Version 315
                    Thank you!! I've flashed that BIOS and am unfortunately still having some issues, but I've started a separate thread for them here. It looks like maybe it wasn't the BIOS that was wrong after all 🙄. Thank you for the quick DMI transferring though, it's much appreciated!
                    • Noursa
                      • Jun 2023
                      • 11
                      • France
                      FX517ZC- bios
                      fine for me thx dude
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • grimacelord
                        by grimacelord
                        07-10-2025, 02:52 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
