HP 840 g10 bios
 tryAttached FilesComment
 Hello, I am really hoping someone can help me out. I've read through dozens of threads on how to remove the BIOS password from a 840 G10, but I have not been able to figure out how to replicate your patched dumps. I receive hundreds to thousands of this model and similar models that need unlocked. Can you help explain how you are patching the BIOS dumps to remove the password? I have all the tools, programmers, and average knowledge regarding this.Comment
 If you want to learn how to unlock password, you must be familiar with repairing bios first. Two indispensable tools are: UEFI Tool NE alpha and HxD.Hello, I am really hoping someone can help me out. I've read through dozens of threads on how to remove the BIOS password from a 840 G10, but I have not been able to figure out how to replicate your patched dumps. I receive hundreds to thousands of this model and similar models that need unlocked. Can you help explain how you are patching the BIOS dumps to remove the password? I have all the tools, programmers, and average knowledge regarding this.↵
 https://www.badcaps.net/donateComment
 Yes, I have both tools and familiar with using these. I know how to pull the DMI info with the UEFI Tool, but can't get it to go into MPM. I'm using a xGecu T56 programmer and know how to unlock any Lenovo, Dell, and most HP laptops, but having a difficult time figuring out the HP 840 G10 or newer models. What do I need to do to unlock these models? Thank you for all your help.Comment
 hi there! i have done to unlocked many 840g10, but today i have one laptop with bios pass. i doing same way, but password still there.even i flash bold new file with clear me and empty DMI
 i dont know bios recovery dmi data from where.Comment
 hi i need bios hp elitebook 840 g10
 SN: 5CG34723N7
 here backupAttached FilesComment
 Hi all, it seems HP have patched MPM from early 2024 and later bios revisions, not only on the 840 G10 I mention below but several other new EliteBook's. Patching the bios through HxD would allow the laptop to go into MPM mode no problem but this is not possible with new bioses, you will be greeted with a 'The Bios has recovered it's identity data from the embedded controller due to data mismatch'. Is there anyway to downgrade the bios with the password active to allow MPM mode again?
 I have attached my original dump and the patched dump which had a 100% success rate before HP patched the bios in new revisions....
 S/N: 5CG4160J23
 Thank you in advance.Attached FilesComment
 Send to you, tyHi all, it seems HP have patched MPM from early 2024 and later bios revisions, not only on the 840 G10 I mention below but several other new EliteBook's. Patching the bios through HxD would allow the laptop to go into MPM mode no problem but this is not possible with new bioses, you will be greeted with a 'The Bios has recovered it's identity data from the embedded controller due to data mismatch'. Is there anyway to downgrade the bios with the password active to allow MPM mode again?
 S/N: 5CG4160J23
 Hello, could you provide me with the unlocked BIOS for my HP 840 G10, this is the original locked one and this is the SN: 5CG90602MF
 Translated to english !Attached FilesComment
 hi guys,
 please i need UNLOCKED file,
 HP EliteBook 840 14 inch G10 Notebook PC
 SerialNumber:5CG53277W1
 hi try and feedbackAttached FilesComment
 i also has one 840g10 with password. The Bios has recovered it's identity data from the embedded controller due to data mismatch.i try to bypass with a new bios copy from other that has password before and unlocked with patched MPM. after pathed laptop can go to bios with red line mpm show on display. i can restore bios factory setting but can't restore security to factory setting (bios ask to password then)Hi all, it seems HP have patched MPM from early 2024 and later bios revisions, not only on the 840 G10 I mention below but several other new EliteBook's. Patching the bios through HxD would allow the laptop to go into MPM mode no problem but this is not possible with new bioses, you will be greeted with a 'The Bios has recovered it's identity data from the embedded controller due to data mismatch'. Is there anyway to downgrade the bios with the password active to allow MPM mode again?
 S/N: 5CG4160J23
 Thank you in advance.Comment
 i need UNLOCK of this file please
 SerialNumber:5CG41148F9
 Thank you allAttached FilesComment
 TryAttached FilesComment
 hi please unlock bios password
 hp 840 G10 sn:5CG3314DCJAttached FilesComment
							Channel: BIOS Requests ONLY!
			by WahazHello,
 I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
			by macabookHello everyone,
 🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
 07-24-2025, 02:17 PM
 Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
 Asus S533F serial L6N0CV190141266
 Current BIOS firmware version is X521FA-305
 Thank you!...-
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
