Need BIOS for Asus G731GW
  • dav_ozk
    • 4
    My laptop is Asus G731GW with I7-9750H cpu and 2070 8gb gpu.
    Motherboard is G531GW rev1.6.
    the system will power on,the fans spins, keyboard backlight turn on , but no internal lcd nor external monitor shows anything.
    I've checked all voltage,everything seems to be ok with schematic in the forum for my laptop.
    when I connect external usb keyoard,the caps lock led deos not light.
    I try to reprogram the bios by reading original firmware and changing ME region. but still no luck.
    I try to use new bios from asus site, but I failed.
    I will upload the original bios firmware I've read from bios chip.
    bios chip is mx25l12873f soic8.
    if someone can help me please.
    best regard
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    best regard
    You MUST:
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules.
    Become a Badcaps supporter
    Thanks to all supporters.
    • dav_ozk
      • 4
      Model Number:G731GW-EV268
      SN:L1NRCV012826029
      Board Model Number:69M19B12C04 G531GW rev1.6
      • skazide
        • Jul 2015
        • 142
        • morocco
        SN:L1NRCV012826029
        try
        • dav_ozk
          • 4
          Thanks , but it doesn't work.
          • skazide
            • Jul 2015
            • 142
            • morocco
            if this not work maybe you have another problem
            • zoltryx
              • Oct 2013
              • 6
              • España
              Hi, I need help with this dump.
              Serial number: L1NRCV02T19804B
              Model: ASUS G731GW-EV178
              I appreciate your help.​
              • hoaca388
                Badcaps
                • Jan 2022
                • 11729
                What's help ? Unlock ? Build new bios ?...
                • zoltryx
                  • Oct 2013
                  • 6
                  • España
                  Thanks for your reply.
                  I need Build new bios, I have tried but with negative results.​
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11729
                    G731GW
                    • zoltryx
                      • Oct 2013
                      • 6
                      • España
                      Thank you very much for your help, at all times I was incorporating 12.0.71.1681_CON_H_BA_PRD_EXTR and that was my fault, I was getting a dump with a delay in booting.
                      I have also tried to add the serial number but without success.
                      With your dump everything is correct, I appreciate your help.​
                      • 789852
                        • Nov 2015
                        • 51
                        • Kazahstan
                        Serial number: KCNRCV011083502
                        Board Model Number: G531GW rev1.6
                        Model: ASUS G731GU-EV005
                          • 20857
                          Post your backup and pictures of QR codes or barcode stickers on the motherboard
                          • 789852
                            • Nov 2015
                            • 51
                            • Kazahstan
                            Thanks, I found a suitable bios, everything works
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • grimacelord
                              by grimacelord
                              07-10-2025, 02:52 PM
                            • throwaway327
                              by throwaway327
                              Model No: RC72LA
                              Serial No: SBNVKD001014459
                              06-18-2025, 05:52 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • tomuso154
                              Need bios for asus strix g531gu or g531gw
                              by tomuso154
                              Hello, I have an
                              Asus Strix g g531gu-al065
                              the board has the markings g531gw rev. 1.6
                              with i7-9750h nvidia 1660ti,
                              SN:K9NRCV01U42136a
                              it looks like this so that all voltages are OK, the laptop "starts" but the voltage is constant
                              1.3A supplied by the service power supply, (I reset the BIOS by unplugging it
                              battery, RAM checked on 2 laptops and 2 slots)
                              It does not provide an image either on the matrix or via HDMI, the fans start running after some time but with no effect
                              constant speed while trying to turn off the laptop by...
                              06-17-2024, 05:51 AM
