HP 250 G6 just backlight on screen
  • peterzz2007
    • Nov 2021
    • 19
    • Slovakia
    Hello all,
    i have HP 250 G6 board nr. DKL50/CSL52 LA-E821P SN# CND8101FN3.
    When i reset BIOS laptop starts and shows some text but when i hit ENTER and laptop reboots there is just backlight visible on the screen,nothing more.
    Pls. fix the original BIOS if possible.
    Thank you!
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Originally posted by peterzz2007
    Hello all,
    Thank you!
    https://www.badcaps.net/forum/showthread.php?t=122195
    [Guide] How to extract ready for programming dump from HP update executable file
    https://www.badcaps.net/forum/showthread.php?t=121948
    Offsets:
    • DMI 3AA000 - 3ABFFF
    • Windows key 3A9000 - 3A903F
    Become a Badcaps supporter
    Thanks to all supporters.
    • peterzz2007
      • Nov 2021
      • 19
      • Slovakia
      Hello Vesko,
      thank you very much for your detailed guide.
      I was able to find right bios version and laptop is working!
      Now i need to fill right DMI data from backup file.
      Thanks again!
        Vesko356 commented
        Editing a comment
        Good job 👍
        You're welcome.
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      09-24-2025, 10:59 AM
    • turmix
      AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
      by turmix
      Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
      The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
      At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
      During another reassembly, I made a mistake, and...
      01-29-2024, 03:48 AM
    • FallenOne008
      Asus G712L No Screen Backlight
      by FallenOne008
      Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
      The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
      03-31-2025, 08:27 PM
    • trepachka
      HP Probook 450 G8 Boardview+Schematics - screen backlight issue
      by trepachka
      I am just wondering if anyone has boardview+schematics for HP Probook 450 G8.
      Computer is missing screen backlight. The backlight fuse must be kaput. I know the fuse is located on the motherboard because we tried a different working screen and it, too is missing backlight.
      Perhaps, if the boardview+schematics are not available, someone can point out where the screen backlight fuse is located. Thanks.
      03-16-2024, 12:32 AM
