Compaq cq 58 no power
  • dj_ricoh
    • 2073
    • uk
    hello my good working ppl
    can someone help me with a bios for this cq58
    P/N: 010172W00-600-G
    NEWTON_BR_HPC
    MV_MB_V1
    ty
  • alihomee
    • Dec 2012
    • 1577
    • malaysia
    Re: Compaq cq 58 no power
    post the full model like cq58-xxxxx
    • robrock1
      • Jul 2013
      • 129
      • Ghana
      have you checked on the board for 3.3v and 5v? if its there then the bios may be corrupted, you have to flash it with an external programmer. If its not there trace the power socket and the power ic. I think there is also a resistor on the board from the middle pin, you have to check from the schematic sometimes its resistance get high so the signal doesn't reach the kbc.
      • dj_ricoh
        • 2073
        • uk
        yes! i kinda need that dump file for bios.
        if someone got a working hp like this use this program and take down the file and put it here plzz:
        https://www.badcaps.net/forum/showth...hlight=utility
        ty
        • dj_ricoh
          • 2073
          • uk
          cq58-241sa
          i`m sry i forgot
          • puscas1983
            • Nov 2013
            • România
            i have a problem with my hp compaq cq58-140sq.
            it wont power on at all
            can u guys help with an advice?
            thanks in advance
            • steved271
              • Jan 2014
              • 29
              • England
              I have a CQ58 by compaq here at the moment that has no power.... You plug the charger in.. The led at the charge port blinks 3 times then goes off....
              It was brought to me by a friend to look at.. I had no power adapter that fit.. So I uses a butchered universal power adapter that I have and soldered on the leads to the correct terminals...
              I now have 19V input power... I have no schematic so if anyone knows where I can get this I would be grateful...
              I have traced the voltage on the charge circuit, that seems to get to the battery fine... Or almost.. As I still have a few points to check as of yet...
              The problem seems to be on the underside of the board... I get 19v in from power jack, it hits first capacitor and then after that I have no voltage at the MOSFET....
              • dj_ricoh
                • 2073
                • uk
                take down the cap and see if its ok.
                how many nF see if its shorted
                • steved271
                  • Jan 2014
                  • 29
                  • England
                  i dont even know if it is a cap or a fuse... as no markings to say what they are at that point on the board...
                  • dj_ricoh
                    • 2073
                    • uk
                    Usualy it has no marking.
                    Take a pic and post it here. Maybe it say near Cxxxx
                    • engmohamedgamal
                      • Sep 2014
                      • mansoura
                      I need Bios hp cq58-301ee
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        did you ever get yours bios dump or schematics? i have almost the same problem
                        https://www.badcaps.net/forum/showthread.php?t=43137
                        Im Back... sort of...
                        • Djosla
                          • Dec 2012
                          • 246
                          • Montenegro
                          cq58-241sa
                          bios is same as for hp655 model...
                          HPCQ58bios.rar
                          • aanan
                            • Dec 2010
                            • 222
                            • India
                            check this.
                            • oxonater
                              • Oct 2012
                              • 77
                              • uk
                              More detailed explanation of my problem is the following laptop came in contact with liquid (juice to be more precise).
                              The laptop (cq58) does not power on I have not tested for voltages and such like just opened it up to visually inspect any problematic areas.
                              I have found a couple of areas on the underside of the processor that have burnt/black caps and an smd chip that looks a little charred.
                              The following caps are discoloured in the corresponding numbered area:
                              cs87,c1314,c1325, black chip seems to be labelled us415
                              Please any help on the values of the caps as I would like to repair thanks in advance
                              • ravi_1617
                                YY Solutions
                                • Jan 2012
                                • 346
                                • India
                                Hi!
                                cq-58 .686280-001 upper ram slot don't allow. to boot ( no display)If only one ram inserted lower slot. boots fine.any checking tips
                                • muzmail
                                  • Aug 2016
                                  • Pakistan
                                  I Need Hp 650 010170100-600-g bios Please Help Me
                                  • Pascal Komlassan
                                    • Jan 2017
                                    • 809
                                    • TOGO
                                    NEWTON_BR_HPC
                                    MV_MB_V1
                                    ty
                                    any help for this bios and the EC
                                    • Pascal Komlassan
                                      • Jan 2017
                                      • 809
                                      • TOGO
                                      NEWTON_BR_HPC
                                      MV_MB_V1
                                      ty
                                      ENJOY YOUR SELF BRO
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • ianbak
                                        Compaq CQ58 with power issues
                                        by ianbak
                                        I'm trying to fix a Compaq CQ58 with power issues. Initially I noticed that it would run on mains power but not on battery, but I have since discovered that it is actually extremely sensitive to the DC power input voltage.
                                        For instance, if I set the charger input to the full 19.5V then everything is normal and it runs absolutely perfectly. However, if I reduce it even to 19.0V it will boot to BIOS level but then just switch off as soon as I put any load on the system (e.g. by running a memory diagnostic). Presumably this explains why it won't run at all on the 11.1V battery supply....
                                        10-21-2023, 05:13 AM
                                        03-31-2024, 02:12 PM
