hp 655 newton_br_hpc bios
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    hello
    does someone happen to have bios dump for amd
    hp 655
    pn: 010172W00-600-G
    NEWTON_BR_HPC
    MV_MB_V1
    it turns on, blink 3 times, pause, blink 4 times and turn off
    3 times blink = ram, but i tried 3 modules, all same
    4 times blink = vga, reflowed but no change (apu vga, cpu soldered)
    tnx in advanced
    here is my not woking dump
    Im Back... sort of...
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: hp 655 newton_br_hpc bios
    That can be bad apu cpu,that ting has tendency to fail...
    here is your dump...
    ah sad vidim brat bosanac...
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      thank you very much...
      i found two more dumps but no go
      in between testing laptop died completely
      giving up on this one...
      @Djosla
      aha brat bosanac se bori sa elektronikom
      ljep pozdrav za CG
      • techman1025
        • Jun 2014
        • 497
        Hi
        Dead GPU heat it to confirm 150c older model always N/B
        Then a must to replace because it will fail again.
        Techman1025
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          Hello i have the same Hp 655 and no display. I try reflow gpu/apu but no help. I can hear that laptop start windows but no display show. Is this need to replace apu/gpu or something else?
          ...the quieter you become the more you are able to hear...
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            try another display, back light may be bad or lcd cable
            • rtstorm
              • Feb 2012
              • 971
              • Croatia
              i just check HDMI and it work, but no display on LCD. I will try to check lcd and cable
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                well i try with another lcd but same thing, can you advise what it coud be?
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  i check the LCD cable but i only get 19V, no other voltages on cable. Is this GPU fail?
                  • reset1986
                    • Dec 2014
                    • 308
                    • italia
                    HP 655 AMD bios dump 4MB
                    hi all are looking for a dump bios for hp 655 4 mb, on the site hp is 4.37MB and I do not know how to work it,
                    The machine sometimes turns on but does not show, sometimes it turns on for 3 seconds and goes off,
                    I wanted to flash the bios but I can not find it correct.
                    this is the corrupt dump done on the failed machine
                    Thanks to who helps me
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: HP 655 AMD bios dump 4MB
                      Try this and report
                      • reset1986
                        • Dec 2014
                        • 308
                        • italia
                        Try this and report
                        thanks, the file is from 4.37mb,
                        the backup is 4mb and is different
                        I have to change the file from 4.37 but I do not know how to do it
                        can you help me?
                        • imranromi
                          • Jan 2015
                          • 1292
                          • Pakistan
                          can you help me?
                          Is better to send board code i try.
                          • reset1986
                            • Dec 2014
                            • 308
                            • italia
                            P/N 010172W00-36V-G
                            Newton_br_hpc mv_mb_v1
                            thanks
                            • imranromi
                              • Jan 2015
                              • 1292
                              • Pakistan
                              P/N 010172W00-36V-G
                              thanks
                              Try here.
                              • reset1986
                                • Dec 2014
                                • 308
                                • italia
                                Try here.
                                thanks
                                I try to flas the bios, update after the post
                                • reset1986
                                  • Dec 2014
                                  • 308
                                  • italia
                                  I programmed the bios, the notebook always does the same problem,
                                  I'm reballing the AMD chipset
                                  I see if I can make it work
                                  • reset1986
                                    • Dec 2014
                                    • 308
                                    • italia
                                    hi friends, I update the post saying that I reballed successfully on the amd chipset, the pc now works perfectly, the problem resided in the chipset, thanks to all for the support
                                    • tysovyc
                                      • Mar 2017
                                      • 11
                                      • zimbabwe
                                      Originally posted by ala_borbe
                                      hello
                                      hp 655
                                      pn: 010172W00-600-G
                                      NEWTON_BR_HPC
                                      MV_MB_V1
                                      tnx in advanced
                                      this bios work perfect it might be your gpu tested it
                                      • tysovyc
                                        • Mar 2017
                                        • 11
                                        • zimbabwe
                                        hello
                                        hp 655
                                        pn: 010172W00-600-G
                                        NEWTON_BR_HPC
                                        MV_MB_V1
                                        tnx in advanced
                                        check fbs11 and fbs7 for gpu power if power is ok then replace gpu or reflow
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                                          by cr4zychriss
                                          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                                          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                                          • Barebone / Chassis: TongFang GK7MRFR
                                          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
