Asus S200E ACPI-incompatible BIOS problems
  • dj_ricoh
    • 2073
    hy guys.
    got a little problem and its taking to long for me to solve it so i come to the neard place again.
    i got this asus that won`t let me install anything.
    everytime i try to boot a os it say that :
    The system its not fully acpi compatible.
    yes i did change acpi for hdd ;ide changed.
    i try to boot only with DVD(external) ...same.
    today i`ll try with ubuntu maybe maybe.
    i downloaded for asus some bios files but those version won`t let power up the machine.
    yesterday i got a same machine and i copy the bios but the problem is:
    - cpu soldered to the board
    -mine got Pentium; other celeron. Maybe not the same bios(with the celeron bios, it powers up but no display)
    Maybe someone got a same machine like mine and wanna share that bios.
    if you see one like this machine plz use this tool and copy the the dam bios:
    https://www.badcaps.net/forum/showthread.php?t=32236
    Thank you
  • Francisco.s
    • 686
    • Spain
    Re: Asus S200E ACPI-incompatible BIOS problems
    I think universal bios backup won´t let anybody to read bios correctly. (if it is a core Ix series)
    Most of core Ix platform, have ec-bios, and main bios, and that is a serious inconvenient.
    Try to boot with Hiren`s, (pres F5 on boot, to circumvent acpi issues) and run Asus bios upgrade** from this environment. (**the upgrade you can dowload from Asus site)
    Perhaps with a bit of luck......
    • dj_ricoh
      • 2073
      i`ll try today. ty
      i need to find a silent boot because not even when i took the other hdd from the celeron vers. i could not boot it.
      got some blue screen
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        you are right...
        • tanveer920
          • Jul 2015
          • 32
          • INDIA
          Try this 100% ok
          • alihomee
            • Dec 2012
            • 1594
            • malaysia
            try this dump
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1356
              • France
              Originally posted by alihomee
              try this dump
              Work perfect thanks
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • grimacelord
                by grimacelord
                07-10-2025, 02:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • vixeko_
                Problems with the asus x456ua laptop bios chip
                by vixeko_
                They asked me to change the HDD to an SSD on this Asus laptop, in case the laptop already had problems such as it not turning on every time and the battery charge lasting very little.
                and perform the task successfully and clone the data from the hdd to the new ssd
                I managed to start windows on the ssd and everything was normal so I decided to restart it to measure the startup speed and when I did that instead of starting windows the laptop sent me to the bios
                I exited the bios to continue to windows but when the laptop turned off it did not turn on again, it was strange but...
                10-19-2023, 06:36 PM
