Lenovo Thinkpad T60 locked bios
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    Hi. I buy 4 this laptops on auktion (as is) and all 4 got locked bios, not possible to do nothing with this, because all stop after show thinkpad logo and no thing happend if I push any button on keyboard, no boot from any device, usb, hdd, cd/dvd
    Is any solution to fix this ?
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Lenovo Thinkpad T60 locked bios
    Hard drive has a password. Remove it and see if that makes it continue.
    http://www.thinkwiki.org/wiki/Mainte...BIOS_passwords.
    • primoz1
      • Oct 2010
      • 270
      • Italy-Slovenia
      Hi. On start I had the same idea, but even if I start laptop without HDD still requires a password.
      • vinceroger69
        • Mar 2012
        • 6714
        will this work?
        1
        Turn on or restart your IBM Thinkpad T60.
        2
        Watch for the message on screen that reads "To Interrupt Normal Startup." When you see this message, press and then release the blue button labeled "ThinkVantage" on your T60.
        3
        Highlight "Start Setup Utility" and press "Enter" to select it. This will unlock the BIOS on your IBM Thinkpad T60 and you will now be able to access it.
        • dycc
          Vision
          • Nov 2011
          • 625
          • Côte d'Ivoire
          https://www.badcaps.net/forum/showth...light=ibm+bios
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            https://www.badcaps.net/forum/showthread.php?t=18615
            • aditya11tt
              Banned
              • Mar 2016
              • 7
              • india
              removing of atmel ic also works it acts as A Security chip
              • Esse
                • Apr 2014
                • 317
                • TOGO
                PLEASE can someone show me the security chip or the atmel chip on this laptop?
                • electronica
                  • Apr 2014
                  • 87
                  • algeria
                  http://www.ja.axxs.net/t60_t60p.htm
                  https://www.youtube.com/watch?v=cQzygBhz830
                  • Esse
                    • Apr 2014
                    • 317
                    • TOGO
                    Please i am not seeing the Atmel 24RF08 chip on the board.is that chip replace by another one?if yes then what is its name.
                    • imranromi
                      • Jan 2015
                      • 1288
                      • Pakistan
                      not i think is atmel chip look near ram slot inside side black cover.
                      • bluestone
                        • Jun 2011
                        • 343
                        • Ghana
                        short both pins after you press power and press F1 immediately after
                        • Esse
                          • Apr 2014
                          • 317
                          • TOGO
                          Bluestone,when i short the pins the T60 doesnt show any display and when i remove the short the display comes.any idea
                          • Esse
                            • Apr 2014
                            • 317
                            • TOGO
                            please Dycc,can i use the simple-i2cprog(SIPROG) interface to read the EEPROM of T60?
                              • 30991
                              NO.
                              if you try to read a 24RF series the security mode will erase the content.
                                • 30991
                                http://www.whatsmypass.com/hacking-i...-bios-password
                                • bluestone
                                  • Jun 2011
                                  • 343
                                  • Ghana
                                  you have to put it on first make sure u see the ibm logo before shorting the pins and then you press f1 immidiately
                                  • Esse
                                    • Apr 2014
                                    • 317
                                    • TOGO
                                    ok
                                    • Kibbs
                                      • May 2023
                                      • Uganda
                                      IBM Thinkpad T60 power on password
                                      Hello
                                      My Collegues IBM Thinkpad T60 laptop has a power on password and it can't get past that stage of which he forgot the password.
                                      Any help from you guys how i can go about it
                                      Thanks.
                                      • fulaphex
                                        Lenovo Thinkpad X13 Gen 3 AMD locked bios
                                        by fulaphex
                                        hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                                        I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                                        07-09-2025, 07:04 PM
                                      • EleganceArog
                                        Lenovo ThinkPad X13 Yoga Gen 3. BIOS LOCKED. Need Bios to be cleared.
                                        by EleganceArog
                                        I have a
                                        S/N: [PW-042W7M]
                                        Type Number: [21AXS1B200]
                                        Motherboard: [LLX-2 MB 213016-SB]
                                        Bios is locked with a Password. I'm looking for a cleared bios bin to flash the laptop.
                                        I attached my backup bios.
                                        Thanks in advance......
                                        02-16-2024, 12:58 AM
                                      • RMDUiFT
                                        Should I buy a Lenovo Thinkpad E495 with bios password?
                                        by RMDUiFT
                                        Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                        I have a few questions:
                                        • If I would buy this laptop and have
                                        08-25-2024, 09:00 AM
                                      • akwky
                                        by akwky
                                        Hi!
                                        04-14-2025, 01:56 PM
                                      • Wahaz
                                        by Wahaz
                                        10-30-2023, 08:42 PM
