HP Elitebook 645 G10 BAD BIOS
  • hpboy
    • Jan 2021
    • 53
    Elitebook 645 G10 - Serial number change
    I have an Elitebook 645 G10 which has has a replacement motherboard. The problem is I cannot update the serial number and DMI data by using all the usual methods - each time I try NdBMFit it reports that either the version does not work with the plaftorm, or is editing mode is locked and I cannot unlock it.
    if I post the dump here, can someone help me to enable editing mode so I can update the serial numbers? Unfortunalty the "new" motherboard is linked to a company so during windows setup I am pushed to a company to signin (even if I bypass this and get into windows WnDMIFit will not run as the "platform is not supported".
    Any help will by much apprciated. thank you
      • 22160
      Post your backups, both chips.
      • hpboy
        • Jan 2021
        • 53
        Thanks SMDFlea. Attached are both the BIOS and EC backups. Please could someone enable MPM (or "clean" the files) so I can update the serial number and data?
        Serial - 5CD4291NPM
        Prod - 7Z0V1AV
        Model - HP EliteBook 645 G10
        Thank you very much
        • hpboy
          • Jan 2021
          • 53
          Serial - 5CD4291NPM
          Prod - 7Z0V1AV
          Thank you very much
          Would be really greatful if someone can help... thank you
          • osman68i
            • May 2015
            • 354
            • The Netherlands
            #65
            try
            • hpboy
              • Jan 2021
              • 53
              Originally posted by osman68i
              try
              Thank you my friend - unfortunately that did not work. On boot "a mismatch in security - restoring" error was shown and it rebooted into the same original state. Do you have any other ideas please?
              • osman68i
                • May 2015
                • 354
                • The Netherlands
                #67
                sorry I have no other idea.
                but you can try to use the ec and bios from the other board.
                  • 22160
                  try these, flash both.
                  • hpboy
                    • Jan 2021
                    • 53
                    Thanks SMDFlea, really apprecaite your efforts. These did not work either.. laptop booted and bios reported "Hp SureStart Detected an unauthrised change in secure boot keys" then "There is a problem with the end point security controller". I went into the BiOS and still reset all to factory, but MPM is still not enabled.
                    I am at a loos, do you have any other ideas? The files that rex98 created here (https://www.badcaps.net/forum/troubl...s-needed/page4) for the 440 G10 worked fine on the 440 G10.
                    Do you know if there is a way to create a "clean" version of the files for this HP 645 G10 in a similar way to the rex98 files?
                    Really do appreacite your help..
                      • 22160
                      flash the original EC_bios and the main bios i posted, see what happens then
                      • hpboy
                        • Jan 2021
                        • 53
                        Thank you SMDFlea - Unfortunatley that did not work either. This time though it did run a bios update, but then returned with "Hp SureStart Detected an unauthrised change in secure boot keys" then "There is a problem with the end point security controller" again, and MDM is not enabled. Try manually enabling again via BiosConfigUtility and it still returns an "access denied" error when trying to write back the MDM enable flag.
                        Anything else you can think of please?
                          • 22160
                          A new main bios to try. If it boots press F10 reset defaults, reboot reset security. Use your original EC_Bios
                          • volinakis
                            • Jan 2021
                            • 2875
                            • N/A
                            #73
                            "laptop booted and bios reported "Hp SureStart Detected an unauthrised change in secure boot keys" then "There is a problem with the end point security controller". I went into the BiOS and still reset all to factory, but MPM is still not enabled."
                            So let me understand: you were able to enter in bios setup and checked in Security if there's no password?
                            • rex98
                              • Feb 2023
                              • 1297
                              • Mandaue CEBU, Philippines
                              #74
                              I noticed there's a lot of unlock request for this model HP ELITEBOOK 645,655 14 inch G10
                              The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
                              first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
                              use BCU and put your original DMI.
                              frequently asked questions:
                              can i use this to my HP ELITEBOOK 645,655 14 inch G10- yes
                              This is only for BID V77 only if you have different BID it won't work. ​
                              • hpboy
                                • Jan 2021
                                • 53
                                YES!!! It worked!
                                rex98 - you are a genius!
                                rex98 SMDFlea volinakis and osman68i - Guys, thank you so so much for all your help, you have no idea how much your help means to me.. thank you! I am now off to study and compare the files so I can try and learn to do this too!
                                Please let me know how I can buy you a beer/coffee/make donation as a way of thanking you.. really do appreciate your support! Thank you!
                                • farouk_1994
                                  • Mar 2021
                                  • 399
                                  • algeria
                                  #76
                                  Hello i have this hp 645 G10 locked bios
                                  SN:5CD4161922
                                    • 22160
                                    SN:5CD4161922
                                    Read https://www.badcaps.net/forum/troubl...46#post3667246
                                    • Ghost18_07
                                      Zakaria
                                      • Mar 2018
                                      • 87
                                      • Algeria
                                      #78
                                      Hello, i want to ask about the BID , here as rex98 said that we should have BID V77 , and how can i know ?
                                        • 22160
                                        Search for V77 with a hex editor https://www.badcaps.net/forum/troubl...flash?t=122195
                                        • Ghost18_07
                                          Zakaria
                                          • Mar 2018
                                          • 87
                                          • Algeria
                                          #80
                                          Thank you SMDFlea,
                                          I have this HP 645 G10 with locked BIOS, thanks in advance.
                                          SN:5CD3459WWN
                                          BTW, i tried the rex98's way but without any luck.
                                          • Wutru
                                            HP Elitebook 820 G4 BIOS repair assistance required
                                            by Wutru
                                            Hi guys,
                                            If someone would be able to provide some expertise, I'd be very grateful.
                                            BIOS Corruption - Cause
                                            So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                            After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                            09-06-2025, 10:32 AM
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
