HP Elitebook 645 G10 BAD BIOS
If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
Subscribe to support us. It only takes 1 minute:
https://www.badcaps.net/settings/subscriptions -
Thank you very much i found the solution.
i will try to learn by comparing your unlocked dump with my locked one
Thanks againComment
What method did you use to unlock this? I'm using RCUnlocker and it says I need to use a 16MB chip but this 32MB W25Q256JV chip is the only one I see. Thanks!Comment
Hello, thank you for sharing, I have the same laptop with password, I flashed this one, it worked no more password on the other hand it is blocked in manufacturing mode, can you tell me what is the DMI so that I can modify the bios with the original DMI please, or unlock my bios if it is simpler, because RCUNLOCK does not work with 32MB
HP 645 G10 SERIAL 5CD347C1TDAttached FilesPremium supporters get full download access and other benefits.
Send to you, try !!
Yes I tried but it doesn't work after restarting I still have the manufacturing
I tried to do it myself in CMD it tells me that it will be corrected but after restarting it remains the same
I would like to know why I always have the same problem, I tried several times, each time when restarting I always have the manufacturing message followed by a blank page indicating a product information not valid error. When I reopen the config file to redo it I realize that it is always on *unlock, so it is never savedComment
Can anyone help me to unlock hp EliteBook 645 G10
motherboard : DA0X9TMB8D1 REV D
SerialNumber:5CD3284DW4
ProductConfigurationID:75C20AV
Board CT Number:PSBYR058JIB06N
Name:HP EliteBook
ProductName:HP EliteBook 645 14 inch G10 Notebook PC
BuildID:23WWKNBZ601#SABY#DABY
rename config.tkt (???) or read again with BCU bios settings and name your file config.txt Open file with notepad and edit it with name, CT, etc - provided by minhdigital move * from Manufacturing Programming Mode to lock - as minhdigital indicate in Note.txt, save as config1.txt (save it in Documents and move it in BCU folder) and use BCU to write file : biosconfigutility[space]/set:config1.txt
I would like to know why I always have the same problem, I tried several times, each time when restarting I always have the manufacturing message followed by a blank page indicating a product information not valid error. When I reopen the config file to redo it I realize that it is always on *unlock, so it is never saved-----------------------------------------------------
please support this forum
-----------------------------------------------------Comment
that's exactly what I did, but it starts without taking the modification, now it doesn't want to start normally, I must have done something stupid, it starts displays a hp sure smart recovery whitepaper error and turns off, I reflashed the original bios and it does exactly the same thing to me, it doesn't even boot on Windows anymore, it turns off after the error, can you clean the original bios please, I don't know what to do anymore
rename config.tkt (???) or read again with BCU bios settings and name your file config.txt Open file with notepad and edit it with name, CT, etc - provided by minhdigital move * from Manufacturing Programming Mode to lock - as minhdigital indicate in Note.txt, save as config1.txt (save it in Documents and move it in BCU folder) and use BCU to write file : biosconfigutility[space]/set:config1.txtAttached FilesPremium supporters get full download access and other benefits.
Send to you, try again !!
that's exactly what I did, but it starts without taking the modification, now it doesn't want to start normally, I must have done something stupid, it starts displays a hp sure smart recovery whitepaper error and turns off, I reflashed the original bios and it does exactly the same thing to me, it doesn't even boot on Windows anymore, it turns off after the error, can you clean the original bios please, I don't know what to do anymoreAttached FilesPremium supporters get full download access and other benefits.
Send to you, try !!Attached FilesPremium supporters get full download access and other benefits.
Hi! Can anyone help me to unlock a HP EliteBook 645 G10
S/N 5CD4058S75
This is the EC FileAttached FilesPremium supporters get full download access and other benefits.
EDIT: i was wrong posting the EC File, this is the MAIN BIOS fileAttached FilesPremium supporters get full download access and other benefits.
by WutruHi guys,
If someone would be able to provide some expertise, I'd be very grateful.
BIOS Corruption - Cause
So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....-
Channel: BIOS Requests ONLY!
by STKR123Greetings badcaps community,
I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
I learned that desoldering...10-29-2024, 06:03 AM -
by macabookHello everyone,
07-24-2025, 02:17 PM -
by wrinexHi i received a HP elitebook G6 that had a The HP Endpoint Security Controller error when booted but 3 enters later you could use it in windows, i thought maybe a bios update helps...... i used the HP tool (it did not want to update from device manager,,, someting i did not even knew worked) after the update it bricked the laptop.
i get 7 blinks on the capslock and thats it. i desoldered the chips front and back. and made a dump. i tried one bios posted here for the 16M and the 32Mb bios.. but it would not turn on or give an error code. so now i reflashed it back in its failed state...-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
- Loading...
