Lenovo E14 Gen2 BIOS request
  • rumpumpel1
    • Jul 2019
    • 143
    • germany
    Hi, I have an E14 Gen 2 AMD with a BIOS password.
    MTM: 20TA000EGE S/N unit: PF39P83A S/N board: L!HF1A6056Z
    I tried to delete the areas starting with 0003D3C0 and 0003EF00 in the EC dump, as I did for an E14 Gen 3 AMD. But here this didn't work.
    Would be nice if someone could tell me which areas I need to delete.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1224
      • France
      This is not your original file, has it already been modified???
      try 00 or FF or remod
      • rumpumpel1
        • Jul 2019
        • 143
        • germany
        I don'r know, if someone before me already tried to remove the password. I noticed, that the area starting with 0003D3C0 was somehow cleaned.
        Ok, I'll try to write 00 into these two areas.
        • rumpumpel1
          • Jul 2019
          • 143
          • germany
          When writing 00 into these two areas, the laptops says "Bad SVP data, process stopped".
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1224
            • France
            you tried all my provided files
            20TA intel
            20T6 AMD
            Click image for larger version  Name:	image.png Views:	0 Size:	5.8 KB ID:	3645188
            serial number of dump 1S20T6000TGEPF20FQNN PF20FQNN
            Motherboard number 8SB20W48136 L1HF0BK042J
            Model of dump 20T6
            Ec version R1AHT32W
            Click image for larger version  Name:	image.png Views:	0 Size:	3.9 KB ID:	3645192
            where is the real ??
            try and restore with golden key
            • rumpumpel1
              • Jul 2019
              • 143
              • germany
              #26
              sorry, my fault. I mixed up two laptops.
              In the meantime I have found my mistake, a very stupid mistake: when writing 00 in the area starting with 0003EF00, I accidentally had 8 bytes starting with 04 07 in the HexEdit buffer instead of starting with 00 00. Apparently the laptop complained about wrong SVP data.
              So the procedure for deleting the password is exactly the same, as for the E14 Gen3 (AMD).
              • badnocap
                Cappy a Baddy
                • Jun 2025
                • 6
                try
                Hi everyone!
                I’m curious if this file will work on any E14 Gen 2 machine and if so, how would I go about loading it? My guess is that it probably won’t, since most people share their serial numbers and other system details.
                I recently bought what seemed like a fantastic deal on an E14 Gen 2, only to find it locked down at the BIOS level (it looks like CompuTrace/Absolute Persistence) and then asking for BitLocker on boot (which I assume is just the SSD encryption). I’ve thought about trying to desolder the BIOS chip with a heat gun though I’m not even sure how many layers there are to tackle! More realistically, I might hire someone with the right programming hardware and skills, but that could get expensive.
                So here’s what I’d love to know:
                1. Skill level: How much expertise do you need to safely remove or flash the BIOS chip?
                2. Tools & software: What hardware (programmer, clip adapters, etc.) and software would be required?
                3. Process overview: What are the general steps involved, and are basic tools (heat gun, soldering iron, alligator clips) enough, or would I need more specialized equipment?
                I’ve searched around the forum but haven’t found clear answers. Sorry if this isn’t allowed here. Just let me know, and I’ll happily remove my post. Thanks so much for any advice!
                • peste
                  • Dec 2016
                  • 12742
                  • ROMANIA
                  #28
                  Originally posted by badnocap
                  Hi everyone!
                  post S/N, full name and model, motherboard model,etc.
                  post the original contents of the bios chip..
                  The bios chip must be unsoldered from the board before writing or reading..
                  do not use the clip, you may have errors..if you do not have anything to unsolder it with,
                  solder wires between the programmer and the bios chip..
                  you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                  • badnocap
                    Cappy a Baddy
                    • Jun 2025
                    • 6
                    peste Hey there! Thanks so much for all the info so far. I was wondering if you might have a step-by-step guide for working with Lenovo machines and specifically what hardware and software I’d need. I spotted this budget-friendly module on Amazon (https://www.amazon.com/ABSOK-CH341A-...dp/B08HH6CPVF/) but I’m not 100% sure it’s a match for the job. Since my machine’s already pretty much a brick, I’ve got nothing to lose by trying it out. Also, do you have any software recommendations for dumping the firmware and then reloading it, if I can get that far? If these topics have already been covered somewhere, please send me the link. I'll be happy to remove my posts so I don’t clutter up the community. Thanks again!
                    • peste
                      • Dec 2016
                      • 12742
                      • ROMANIA
                      #30
                      https://www.badcaps.net/forum/showpo...6&postcount=10
                      https://www.badcaps.net/forum/showpo...04&postcount=7
                      • badnocap
                        Cappy a Baddy
                        • Jun 2025
                        • 6
                        Questions I have outside of generously asking for a fixed version of this BIOS are:
                        - Do I need to remove BitLocker first (how to do PROPERLY?)?
                        - Do I need to worry about an "EC"?
                        - How do I flash whatever files I get back?
                        I made this dump using the following in Ubuntu Linux: `sudo flashrom -p ch341a_spi -r backup1.bin`
                        Model: E14 Gen 2
                        Type: 20T6-002QS
                        Board: NM-C771
                        Serial: PF-2PF0NR
                        Here is a picture of the chip and the machine has BitLocker activated. I remember reading somewhere that you should "somehow" remove BitLocker first because of the TPM on the board. I have not read anywhere yet how to do that or what my next steps are should I get back a supposedly working BIOS...
                        Picture #1: BitLocker screen
                        Click image for larger version  Name:	IMG_1357.jpg Views:	0 Size:	670.7 KB ID:	3668651
                        Picture #2: BIOS
                        Click image for larger version  Name:	IMG_1360.jpg Views:	0 Size:	1.49 MB ID:	3668652
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1224
                          • France
                          #32
                          Reinstall Windows with usb key , format disk and new install
                          why did you make a double post
                          https://www.badcaps.net/forum/troubl...96#post3672396
                          • badnocap
                            Cappy a Baddy
                            • Jun 2025
                            • 6
                            Thank you! I didn't know who monitors which threads; usually I saw posts responded to very quickly after so after some time I decided to bump this on a related thread.
                            • badnocap
                              Cappy a Baddy
                              • Jun 2025
                              • 6
                              peste are you able to help with my request here?
                              Hi, need Bios for Lenovo: Model: E14 Gen 2 Type: 20T6 Board: NM-C771 Serial: PF-243EBQ Power LED is blinking, when power on, no screen, no fan, no beeps. Please find actual bios attached.
                              • Wahaz
                                by Wahaz
                                10-30-2023, 08:42 PM
                              • madrali
                                lenovo e15 gen2 bios ? problem
                                by madrali
                                Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                                20TD-50S0KU00
                                Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                                I used Lenovo's SmartBeep decoder and it returned error 0284:
                                "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                                I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                                06-16-2025, 12:06 PM
                              • HammyCheesy
                                Lenovo ThinkStation P720 BIOS Request
                                by HammyCheesy
                                Hello all,
                                I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                Type: 30BB
                                Model Number: S03600
                                S/N: MJ07N68C
                                Things I have tried:
                                1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                2. Attempted to boot with just a single CPU...
                                04-11-2025, 01:02 AM
                              • grimacelord
                                Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                                by grimacelord
                                Hello there.
                                I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                                History:
                                1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                                I searched for this error online and discovered...
                                03-15-2023, 03:29 PM
                              • jbonavita
                                by jbonavita
                                Some issues
                                Things I tried
                                04-29-2025, 09:38 PM
