I matched the BIN before programming... Header was 100% same on both but in the middle the DATA was different. You did it very well & the BIOS even was read perfectly. For where did you get the FF FF photo, in the start it was all yy on both???? We are using the RT809H programmer, the program gives the right match for the chip with voltage. This is a 1.8V chip 256KB. Thanks
thinkbook 14,15 g4 iap bios bin NEED
Link to schematic - https://www.badcaps.net/forum/troubl...and-schematicsComment
I used Neoprogramer 2.2.0.10. and CH341 flasher I2C protocol socket. Just 2 days ago I ordered SOP8 DIP8 connectors and 1,8V adapter, hoping that I would flash the BIOS chip of this laptop, thinking that the BIOS chip is 1,8V supplied. According to boardview the BIOS chip was supplied with 3,3 V, I also measured with multimeter right on the motherboard and the supply voltage was 3,3V, datasheet says supply voltage 1,8 - 5,5V. The same is with the U15 chip, I checked datasheet and range is 1,8 - 5,5V. On boardview the supply voltage for PD controller memory is 3,3 Volts. Neoprogrammer recognized the chip as 3,3V so I proceded with that voltage. Anyways, I am happy for You, that the laptop is ON again.Comment
Customer feedback while updating bios the machine turned off.
When you press the power button, the machine runs for 5 seconds and then turns off.
Сould someone help me repairing my original dump?
Thanks in advance.
device:Laptop
brand :LENOVO
Model :THINKBOOK 15 g4 iap
Board no:LA-L931P ,rev1.0
S/N: MP2ЕЕЗ63Attached FilesComment
Thanks in advance.
device:Laptop
brand :LENOVO
S/N: MP2ЕЕЗ63
Attached Files↵
https://www.badcaps.net/donateComment
Help unlock pls
thinkbook 14 G4 iap
sn: mp29km1f
LA-L931P rev: 1 .0Attached FilesComment
hi try feedbackAttached FilesComment
HI tryAttached FilesComment
Hi
Can you please help me remove password from this bin file
thinkbook 14 GA iap
SN MP2JWLM
Board ID LA-L931PAttached FilesComment
Hi danito. Thanks for your help. I really appreciate it. After flashing your unlocked file the computer won’t turn on.(the power button lights up for a couple of seconds and then it turns off. The computer seems to be charging the battery just fine) I tried one of the files shared by one of the guys on this post. The computer turned on fine but hard drive is not detected obviously because the bin file I flashed is for 15 model and mine is 14. Could you please advise as to what I should do next. ThanksComment
Hi danito. Thanks for your help. I really appreciate it. After flashing your unlocked file the computer won’t turn on.(the power button lights up for a couple of seconds and then it turns off. The computer seems to be charging the battery just fine) I tried one of the files shared by one of the guys on this post. The computer turned on fine but hard drive is not detected obviously because the bin file I flashed is for 15 model and mine is 14. Could you please advise as to what I should do next. ThanksAttached FilesComment
Last edited by volinakis; 10-03-2025, 09:33 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi danito. Thanks for your help. I really appreciate it. After flashing your unlocked file the computer won’t turn on.(the power button lights up for a couple of seconds and then it turns off. The computer seems to be charging the battery just fine) I tried one of the files shared by one of the guys on this post. The computer turned on fine but hard drive is not detected obviously because the bin file I flashed is for 15 model and mine is 14. Could you please advise as to what I should do next. ThanksAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by AhariHi all,
I...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maciek1221Hello, I'm Looking MP2964R dump in laptop Lenovo Thinkbook 16 G6 IRL, marking on the motherboard is:
ThinkBook 16 Gen6
223147-1.
448-0TF06.001
On motherboard are:
procesor - SRMLX Intel Core i5-1335U
KBC - Nuvoton NPCE48ALA1DX
BIOS - Winbond 25R256JVEN
MTM:21KHS00P00
S/N: PW08Q287
Old MP2964R is burned after water spill.
Have a nice day-
- Loading...
