thinkbook 14,15 g4 iap bios bin NEED
  • mferna14
    • Jun 2018
    • 1026
    I matched the BIN before programming... Header was 100% same on both but in the middle the DATA was different. You did it very well & the BIOS even was read perfectly. For where did you get the FF FF photo, in the start it was all yy on both???? We are using the RT809H programmer, the program gives the right match for the chip with voltage. This is a 1.8V chip 256KB. Thanks
    • bsloboda
      • Mar 2020
      • 8
      • slovakia
      #62
      I used Neoprogramer 2.2.0.10. and CH341 flasher I2C protocol socket. Just 2 days ago I ordered SOP8 DIP8 connectors and 1,8V adapter, hoping that I would flash the BIOS chip of this laptop, thinking that the BIOS chip is 1,8V supplied. According to boardview the BIOS chip was supplied with 3,3 V, I also measured with multimeter right on the motherboard and the supply voltage was 3,3V, datasheet says supply voltage 1,8 - 5,5V. The same is with the U15 chip, I checked datasheet and range is 1,8 - 5,5V. On boardview the supply voltage for PD controller memory is 3,3 Volts. Neoprogrammer recognized the chip as 3,3V so I proceded with that voltage. Anyways, I am happy for You, that the laptop is ON again.
      Link to schematic - https://www.badcaps.net/forum/troubl...and-schematics
      • mferna14
        • Jun 2018
        • 1026
        Thank you very much dear for all the help!!! & the Schematics & Boardview, Admin pls. move the schematics/Boardview to the right location., Thanks
          SMDFlea commented
          Editing a comment
          Thanks, schematics link added .
      • reaper422
        • Oct 2013
        • 13
        • bulgaria
        #64
        Customer feedback while updating bios the machine turned off.
        When you press the power button, the machine runs for 5 seconds and then turns off.
        Сould someone help me repairing my original dump?
        Thanks in advance.
        device:Laptop
        brand :LENOVO
        Model :THINKBOOK 15 g4 iap
        Board no:LA-L931P ,rev1.0
        S/N: MP2ЕЕЗ63​
        • hoaca388
          Badcaps
          • Jan 2022
          • 11807
          #65
          Thanks in advance.
          device:Laptop
          brand :LENOVO
          S/N: MP2ЕЕЗ63
          ThinkBook 15 G4 IAP - Type 21DJ
          • gsm_code
            • Oct 2023
            • 40
            • philippines
            #66
            Help unlock pls
            thinkbook 14 G4 iap
            sn: mp29km1f
            LA-L931P rev: 1 .0
            • gsm_code
              • Oct 2023
              • 40
              • philippines
              #67
              Up pls
              • shiyab
                • Sep 2023
                • 1495
                • india
                #68
                Originally posted by gsm_code
                Help unlock pls
                thinkbook 14 G4 iap
                sn: mp29km1f
                LA-L931P rev: 1 .0
                hi try feedback
                • gsm_code
                  • Oct 2023
                  • 40
                  • philippines
                  #69
                  Originally posted by shiyab
                  hi try feedback
                  Password not remove
                  • shiyab
                    • Sep 2023
                    • 1495
                    • india
                    #70
                    Password not remove
                    HI try
                    • gsm_code
                      • Oct 2023
                      • 40
                      • philippines
                      #71
                      HI try
                      Tnx for helping, its working now no bios password
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • maciek1221
                        Looking for a bios dump in Lenovo Thinkbook 16 G6 IRL
                        by maciek1221
                        Hello, I'm Looking MP2964R dump in laptop Lenovo Thinkbook 16 G6 IRL, marking on the motherboard is:
                        ThinkBook 16 Gen6
                        223147-1.
                        448-0TF06.001
                        On motherboard are:
                        procesor - SRMLX Intel Core i5-1335U
                        KBC - Nuvoton NPCE48ALA1DX
                        BIOS - Winbond 25R256JVEN
                        MTM:21KHS00P00
                        S/N: PW08Q287
                        Old MP2964R is burned after water spill.
                        Have a nice day
                        02-18-2025, 04:48 AM
