thinkbook 14,15 g4 iap bios bin NEED
  • mferna14
    • Jun 2018
    • 1015
    I matched the BIN before programming... Header was 100% same on both but in the middle the DATA was different. You did it very well & the BIOS even was read perfectly. For where did you get the FF FF photo, in the start it was all yy on both???? We are using the RT809H programmer, the program gives the right match for the chip with voltage. This is a 1.8V chip 256KB. Thanks
    • bsloboda
      • Mar 2020
      • 8
      • slovakia
      #62
      I used Neoprogramer 2.2.0.10. and CH341 flasher I2C protocol socket. Just 2 days ago I ordered SOP8 DIP8 connectors and 1,8V adapter, hoping that I would flash the BIOS chip of this laptop, thinking that the BIOS chip is 1,8V supplied. According to boardview the BIOS chip was supplied with 3,3 V, I also measured with multimeter right on the motherboard and the supply voltage was 3,3V, datasheet says supply voltage 1,8 - 5,5V. The same is with the U15 chip, I checked datasheet and range is 1,8 - 5,5V. On boardview the supply voltage for PD controller memory is 3,3 Volts. Neoprogrammer recognized the chip as 3,3V so I proceded with that voltage. Anyways, I am happy for You, that the laptop is ON again.
      Link to schematic - https://www.badcaps.net/forum/troubl...and-schematics
      • mferna14
        • Jun 2018
        • 1015
        Thank you very much dear for all the help!!! & the Schematics & Boardview, Admin pls. move the schematics/Boardview to the right location., Thanks
          SMDFlea commented
          Editing a comment
          Thanks, schematics link added .
      • reaper422
        • Oct 2013
        • 13
        • bulgaria
        #64
        Customer feedback while updating bios the machine turned off.
        When you press the power button, the machine runs for 5 seconds and then turns off.
        Сould someone help me repairing my original dump?
        Thanks in advance.
        device:Laptop
        brand :LENOVO
        Model :THINKBOOK 15 g4 iap
        Board no:LA-L931P ,rev1.0
        S/N: MP2ЕЕЗ63​
        • hoaca388
          Badcaps
          • Jan 2022
          • 11643
          #65
          Thanks in advance.
          device:Laptop
          brand :LENOVO
          S/N: MP2ЕЕЗ63
          ThinkBook 15 G4 IAP - Type 21DJ
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • maciek1221
            Looking for a bios dump in Lenovo Thinkbook 16 G6 IRL
            by maciek1221
            Hello, I'm Looking MP2964R dump in laptop Lenovo Thinkbook 16 G6 IRL, marking on the motherboard is:
            ThinkBook 16 Gen6
            223147-1.
            448-0TF06.001
            On motherboard are:
            procesor - SRMLX Intel Core i5-1335U
            KBC - Nuvoton NPCE48ALA1DX
            BIOS - Winbond 25R256JVEN
            MTM:21KHS00P00
            S/N: PW08Q287
            Old MP2964R is burned after water spill.
            Have a nice day
            02-18-2025, 04:48 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
