HP PROBOOK 450 G8 DAX8QAMB8D0 REV : D Bios needed
try. Write only main bios.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
try this EC. Count how many times charging led is blinking. And check soldering of bios chipsets.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
It flashes endlessly until the charger is removed.
I just found a faulty component that's extremely necessary. It's a PU9502 (G2898). I ordered it to see if that's the problem.Comment
Request: caps lock key on solid and power light flashes endless amber and white.
Device: Laptop Brand: HP EliteBook Model: 450 G8 product
SN: 5CD1277CYV
MB: DAX8QAMB8D0 rev D
I have attached both bios rom and ec rom. thanks in advance.Comment
Hello, after changing the component the problem is still the same. I flashed the ec rom with the file you provided me above but it still doesn't work. Do you have any other idea?Comment
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
- Loading...
