HP PROBOOK 450 G8 DAX8QAMB8D0 REV : D Bios needed
  • Vincovitch
    • Oct 2022
    • 9
    • France
    #81
    Originally posted by volinakis
    did you take off bios chipset from motherboard? Or are you using clamps? Is not a good idea to use clamps, you'll have errors. if you also use Ch341A do 3-4 readings and compare them, when you have 2 identical it means you have a good backup.
    The BIOS is fine, but it's badly soldered on the board.
    Here are the backups.
    • volinakis
      • Jan 2021
      • 2887
      • N/A
      #82
      try. Write only main bios.
      • Vincovitch
        • Oct 2022
        • 9
        • France
        #83
        I just wrote the bios but the problem is the same as soon as I plug in the charger the fan starts running at full speed and the screen is black. Should I also write the EC?
        • volinakis
          • Jan 2021
          • 2887
          • N/A
          #84
          try this EC. Count how many times charging led is blinking. And check soldering of bios chipsets.
          • Vincovitch
            • Oct 2022
            • 9
            • France
            #85
            It flashes endlessly until the charger is removed.
            I just found a faulty component that's extremely necessary. It's a PU9502 (G2898). I ordered it to see if that's the problem.
            • ub6ib969
              • Jul 2010
              • 201
              #86
              Request: caps lock key on solid and power light flashes endless amber and white.
              Device: Laptop Brand: HP EliteBook Model: 450 G8 product
              SN: 5CD1277CYV
              MB: DAX8QAMB8D0 rev D
              I have attached both bios rom and ec rom. thanks in advance.
              • Vincovitch
                • Oct 2022
                • 9
                • France
                #87
                Hello, after changing the component the problem is still the same. I flashed the ec rom with the file you provided me above but it still doesn't work. Do you have any other idea?
                • smallvhin
                  • Jul 2015
                  • 192
                  • philippines
                  #88
                  master pls help to repair my bios blinking caps lock and numLock key. more thanks
                  Hp ProBook 450 G8
                  DAX8QMB28A0 REV:A
                  SN: 5CD145DNWB
                  • smallvhin
                    • Jul 2015
                    • 192
                    • philippines
                    #89
                    Hp ProBook 450 G8
                    DAX8QMB28A0 REV:A
                    SN: 5CD145DNWB
                    7 blinking caps lock and numLock key master🙏
                    • global1
                      • Sep 2013
                      • 34
                      • Netherlands
                      #90
                      Hello everybody,
                      Can someone help me with removing 'ownership tag?
                      HP Probook 450 G8
                      DAX8QMB28A0 REV:A
                      SN: 5CD146D9Q0
                      • danito
                        • Jun 2016
                        • 1301
                        #91
                        Originally posted by global1
                        Hello everybody,
                        HP Probook 450 G8
                        DAX8QMB28A0 REV:A
                        SN: 5CD146D9Q0
                        need Main backup not EC
                        • global1
                          • Sep 2013
                          • 34
                          • Netherlands
                          #92
                          Here is the MAIN BIOS.
                          HP Probook 450 G8
                          DAX8QMB28A0 REV:A
                          SN: 5CD146D9Q0
                          • global1
                            • Sep 2013
                            • 34
                            • Netherlands
                            #93
                            HP Probook 450 G8
                            DAX8QMB28A0 REV:A
                            SN: 5CD146D9Q0
                            Can someone help me remove the 'Ownership Tagl' from the system ID's?
                            HP ProBook 450 G8
                            DAX8QMB28A0 REV:A
                            SN: 5CD146D9Q0
                            Last edited by SMDFlea; 11-20-2025, 06:01 AM. Reason: bios removed, you already posted it.......
