Hi, I have an Asus GL504GS where, using a modded BIOS, settings were saved that rendered it unbootable (no display output on internal or external etc) - pulling the CMOS battery and all other power (battery, AC), leaving for a day, did not reset them. The BIOS recovery procedure does not work. The chip is WSON8, I can remove and reflash it, but I believe I need a full dump.
Knowing which areas to clear out to cause a variable reset/reinitialization to defaults would also help, then I wouldn't need to reflash & could just erase that portion on the chip.
Any help on either end would be greatly appreciated!
EDIT: I have uploaded the stock BIOS 303, as well as a pre-mod dump of the stock 303 BIOS done with (I believe) Intel's FPT.
