lenovo P1 gen1 17870-1 need 32mb bios dump
  • adamgouadma
    • Jul 2017
    • 202
    • setif
    Originally posted by Maxpower3
    which EC? 1653 always
    try bypass with lpc
Name:	Nouveau Image bitmap (2).png
    Yes European Commission? 1653
    I want to clarify more, I've never dealt with this before
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      read here ,not jtag port ,find lpc port
      just need gnd and lad contact
      https://www.badcaps.net/forum/troubl...-ec-pwd-bypass
      example 1653 bypass
      https://www.youtube.com/watch?v=3P1_3g4WeNc
      • adamgouadma
        • Jul 2017
        • 202
        • setif
        example 1653 bypass
        I will try that
        • adamgouadma
          • Jul 2017
          • 202
          • setif
          example 1653 bypass
          I tried and it didn't work for me
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            not easy at first, you have to get used to it.
            errors are produced?
            if not verified that the resistors are present on the path​
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
              by haitham sharabati
              Hello engineers 😀,
              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
              💀 Problem:😅
              - Device shows “Administrator Password”...
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
