HP Probook 450 G9 password
  • nueziel
    • Jul 2023
    • 4
    • philippines
    Need help to remove password from bios. Thanks.
    HP Probook 450 G9
    Serial: 5CD2236GBP
  • volinakis
    • Jan 2021
    • 2872
    • N/A
    Re: HP Probook 450 G9 password
    HP Probook 450 G9
    Serial: 5CD2236GBP
    try this. write only main bios 32Mb. It will enter in MPM mode, 1st time when enter in bios reset to factory defaults, save, restart, then enter again in bios and in Main tab you have "set machine unique data" and write this:
    Feature Byte
    476J6S6b7B7J7M7Q7W7saBapaqauawbUbhcAdpdqfPguk8mEmGmwn7nVpFpTpqqjqz.yG (no spaces)
    Build Id
    22WWRTBT601#SUUF#DUUF
    Serial
    5CD2236GBP
    SKU
    6J8W4PA#UUF
    System Board CT
    PQNNH018JGQ31Z
    Name
    HP ProBook 450 15.6 inch G9 Notebook PC or you can cut it to HP ProBook 450 G9
    after that save and use BCU 4.0 to exit MPM mode or restart laptop how many times counter shows.
    • nueziel
      • Jul 2023
      • 4
      • philippines
      thanks, will try later after work.
      • nueziel
        • Jul 2023
        • 4
        • philippines
        Feature Byte
        Build Id
        Serial
        5CD2236GBP
        SKU
        6J8W4PA#UUF
        System Board CT
        PQNNH018JGQ31Z
        Name
        tried to flash main bios, resoldering and after attaching battery, keyboard lights 5x then when i press power, caps lock and numlock blink 7x simultaneously then powers off. pressing power again makes caps lock and numlock blink 7x.
        btw, it doesn't dislplay anything during the process.
        • volinakis
          • Jan 2021
          • 2872
          • N/A
          remove battery, also cmos battery, plug adapter and wait for 2 minutes, it will restart several times without displaying anything, don't press any button.
          • nueziel
            • Jul 2023
            • 4
            • philippines
            sorry for the lack of update, i have successfully unlocked my laptop. thank you!
            • vlad4volk
              • Aug 2023
              • 5
              • Ukraine
              Hi guys! I`m also have same problem with bios password. Please help me. What shoul I do? Take bios flash from motherboard then... Please, can you make litlle instruction for me?
              • vlad4volk
                • Aug 2023
                • 5
                • Ukraine
                Feature Byte
                Build Id
                Serial
                5CD2236GBP
                SKU
                6J8W4PA#UUF
                System Board CT
                PQNNH018JGQ31Z
                Name
                If I understand right, I can also use this .zip but setup my Serial. Or it harder than I think? Is it possible whitout removing bios flash?
                Sorry for stupid questions, I`m new at this)
                • volinakis
                  • Jan 2021
                  • 2872
                  • N/A
                  no, it's not possible if you have bios password. If you want to change serial, ID, name, etc. and you DON'T HAVE PASSWORD on bios you can use BCU 4.0 or higher.
                  • vlad4volk
                    • Aug 2023
                    • 5
                    • Ukraine
                    No, I want remove password from bios, and save serial, windows key(if it on bios) etc. I just need to install windows (coz now it's working as "to go").
                    • volinakis
                      • Jan 2021
                      • 2872
                      • N/A
                      you can't use another bios from another laptop, your own bios has to be modified. "set UNIQUE machine data" does sound a bell?
                      • vlad4volk
                        • Aug 2023
                        • 5
                        • Ukraine
                        Yes, shure. Is it possible by myself to modify bios? I can remove flash but I don't know how to use Hex editor to remove password...
                        • vlad4volk
                          • Aug 2023
                          • 5
                          • Ukraine
                          I`ve compared bios from top of thread and the one you send, it have just 7 differences. Can I change my bios in same place or it doesent work like that? Also I`ve see solution to find and remove "nvramactiveRegn". Which way is better?
                          • mograinne
                            • Jul 2015
                            • 25
                            • Slovakia
                            Hello I need help with locked bios
                            HP PROBOOK 450 G9
                            DA0X8SMB8H1 REV: H MODEL:X8SA
                            SN: 5CD2301HZM
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12240
                              Originally posted by mograinne
                              hello i need help with locked bios
                              hp probook 450 g9
                              da0x8smb8h1 rev: H model:x8sa
                              sn: 5cd2301hzm
                              thanks
                              hp probook 450 g9
                              sn: 5cd2301hzm
                              • mograinne
                                • Jul 2015
                                • 25
                                • Slovakia
                                Originally posted by hoaca388
                                hp probook 450 g9
                                sn: 5cd2301hzm
                                Thanks so much, working
                                • 01007209444
                                  • Dec 2015
                                  • 5
                                  • mansoura
                                  HP Probook 450 G9
                                  Serial: 5CD2236GBP
                                  this file without password
                                  • chemseddine
                                    • Jul 2017
                                    • 32
                                    • algeria
                                    Feature Byte
                                    Build Id
                                    Serial
                                    5CD2236GBP
                                    SKU
                                    6J8W4PA#UUF
                                    System Board CT
                                    PQNNH018JGQ31Z
                                    Name
                                    hey..why I can not change admin pass in this bios ..... when I enter old pass it sais wrong pass...
                                    • Vesko356
                                      Vesko356 commented
                                      Editing a comment
                                      The bios posted by Volinakis in your quoted post was a reply to a request from another member.
                                      If you have similar model with similar problem post your request adding first all the necessary information as per the rules
                                  • casaba
                                    • Apr 2014
                                    • 25
                                    • morokko
                                    sn:5CD231FWH9
                                    MAINBOARD : DAX8SFMB8B1 Rev-B
                                    ​MODEL:X8SG
                                    • qayyum786
                                      • Aug 2018
                                      • 1958
                                      • INDIA
                                      At 1st boot press F10 and RESET BIOS to factory defaults
                                      use HP BCU for MPM error
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        Ack
                                        Ack
                                        01-30-2025, 04:26 AM
                                      • Soumana Sanou
                                        “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                        by Soumana Sanou
                                        Hello,😇😇😇
                                        I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                        🔧 Model: HP ProBook 11 G2
                                        📦 Serial Number: 8CG72478MY
                                        🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                        🔒 BIOS Status: Locked with password
                                        The laptop is no longer under warranty and HP refused to help me.
                                        I’m looking for a custom SMC.bin file.
                                        I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                        Thanks a lot for your help!🙏🙏🙏...
                                        06-17-2025, 04:04 PM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • RMDUiFT
                                        Should I buy a Lenovo Thinkpad E495 with bios password?
                                        by RMDUiFT
                                        Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                        I have a few questions:
                                        • If I would buy this laptop and have
                                        08-25-2024, 09:00 AM
