HP Probook 450 G9 password
I have an HP ProBook 450 G9.
I need to remove the administrator code from the BIOS to reset the PC.
I extracted the BIOS chip dump, but I don't know if this is the correct chip to take the dump from.
Serial number 5CD3091R26
Thank you in advance.Attached FilesPremium supporters get full download access and other benefits.
Hello again
I forgot the motherboard number DA0X8SMB8H1 REV: H. I have a doubt about the dump!!!
For the dump, I copied it from the top chip, not the EC.
Thank you.Comment
You will need to write down both microchips (main+ec) and write down your details (serial number, laptop model, etc.) manually.
The file you posted is too small it`s only 256KB ,you have chosen the wrong chip yourself or the programmer auto-detect selected the wrong one.Comment
Hello I have a GQ4X programmer, but the chip reference isn't in it. I tried the closest one, but apparently without success. I ordered a CH341a programmer today. Once I receive it, I'll read the chip and reapply it, as well as the EC. Thank you for your reply.Comment
Hello Xander 007 and Chip SMD
Please remove bios and EC password.
What should I do once rewritten?
Here are the original dumps
HP ProBook 450 G9
Motherboard number: DA0X8SMB8H1 REV: H
Serial : 5CD3091R26
Thanks to youAttached FilesPremium supporters get full download access and other benefits.
Please delete the BIOS and EC password.
What should I do once it's overwritten?
Here are the original dump files I managed to read by unsoldering the chips:
HP ProBook 450 G9
Motherboard Number: DA0X8SMB8H1, Revision: H
Serial Number: 5CD3091R26
Thank you.
Hi Guys,
Please need to unlock this HP 450 G9
S/N : 5CD3045ZY2Attached FilesPremium supporters get full download access and other benefits.
try and feedbackAttached FilesPremium supporters get full download access and other benefits.
plz clear me bios password hp probook 450 g9 sn# 5CD238F5MPAttached FilesPremium supporters get full download access and other benefits.
by chriswfrye21Hi everyone,
I’m working on an HP 255R 15.6" G10 Notebook PC that has a BIOS Administrator / Setup password I cannot bypass. I can boot Windows normally, but F10 is completely blocked unless the password is entered. I do not know the password.
This is not a Power‑On Password. This is a BIOS Admin password stored in NVRAM, and the system will not allow BIOS access at all.
I’m posting here to get help identifying the correct procedure, dump, or method needed to clear the password on this model. System Details
Model: HP 255R 15.6 inch G10 Notebook PC SK...-
Channel: BIOS Requests ONLY!
by Olegst44Hello everyone,
I need help with BIOS password removal for Acer Aspire 3 A315-22G laptop.
Device Information:
- Model: Acer Aspire 3 A315-22G
- Motherboard: NB8607G02-MB (Compal LA-J761P)
- BIOS Chip: Winbond W25Q64 (8MB)
- Serial: NXHE7ER00X95002B784S00
Problem:
- BIOS is password protected (Supervisor Password)
- Boot from USB is disabled in BIOS
- After 3 wrong password attempts, system shows Unlock Key Hint
- I have RT809H programmer available
What I need:
1. Clean BIOS dump (password...-
by TopPopSorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip... -
by scOOb_IIHi everyone,
I am trying to remove the BIOS Administrator Password on an HP ProBook 4730s.
The automated HPBR/DOS scripts fail due to unsupported motherboard ID (167c).
Here are the details from my system:- Laptop Model: HP ProBook 4730s
- System Board CT number: PCMGK001Y1Y3BH
- SKU / Product Number: LY490EA#ABH
- Serial Number: CNU2051C5C
- UUID: 0xCD979811D57FE0119C1C05E22F0340F6
Kind regards & many thanks in advance...-
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... - Loading...
