HP Probook 440 G8 BIOS Password
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    read and post another bios chip its a ec not main spi. Before posting your backup here chk the status 1 time in Meanalyzer
    • krogs214
      • Sep 2017
      • 84
      • Philippines
      Hi help me to disable absolute (device freeze 415 issue)
      HP PROBOOK 440 G8
      SERIAL NUMBER 5CD145J1Q5
      BOARD NUMBER: DAX8QMB28A0 REV A
      • volinakis
        • Jan 2021
        • 2874
        • N/A
        HP PROBOOK 440 G8
        try
        • krogs214
          • Sep 2017
          • 84
          • Philippines
          Originally posted by volinakis
          try
          THANKS IT WORKS
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            THANKS IT WORKS
            you are welcome.
            • krogs214
              • Sep 2017
              • 84
              • Philippines
              #26
              you are welcome.
              hi everytime i turn off the laptop i always need to remove the battery and the cmos battery to turn on again/display and sometimes this message always pop up ,
              • rex98
                • Feb 2023
                • 1293
                • Mandaue CEBU, Philippines
                #27
                use that give feedback please.
                • Dan20701
                  • Sep 2020
                  • 204
                  • United Kingdom
                  #28
                  Hello all, I am having a problem with a 440 G8.
                  This one came as part of a joblot, the bios chips was both missing, I have got the laptop working with some downloaded bios files
                  I am getting the End Point Security Error, and need to contact HP
                  I have tried many files and these are the only files that boot and I am not sure if its finding the ssd drive. in the bios setup it says 450 G8
                  The dmi info below is from the serial number on the back cover and hp partsurfer. It will not be the same as in the bin files
                  its not important to have the correct dmi info hopefully I can edit this after.
                  Serial Number : 5CD1077X3D
                  Product Number : 2X7U0EA
                  Description : HP ProBook 440 G8
                  BID=20WWR3CT601#SABU#DABU
                  FEATUREBYTE : 3X476J6S6b7B7J7M7Q7W7m7saBapaqauawbUbhcAdUdpdqfPguk8mE.qH
                  Can someone work there magic on this one please if its possible.
                  Or if anyone has a working set with no errors they could share that would be great.
                  ​Thanks for trying to help.
                  • kros
                    • Oct 2017
                    • 18
                    • IE
                    #29
                    Dan20701 Check your bios and let me know if it helped​
                    • Dan20701
                      • Sep 2020
                      • 204
                      • United Kingdom
                      #30
                      Thanks for trying mate, not much is happening when pressing the power button the caps button flashes 7 times. Thanks.
                        • 21984
                        Clean the ME firmware first, its initialised (check it with MEAnalyzer) . After cleaning the ME FW try the VSS2 fix using UEFITool and a hex editor https://www.badcaps.net/forum/troubl...55#post3310855 .The offsets in your bios are different 188A048 - 18C7FFF
                        If you can`t do that with a hex editor try the patcher https://www.badcaps.net/forum/troubl...security-error
                        • Dan20701
                          • Sep 2020
                          • 204
                          • United Kingdom
                          #32
                          I got it working now thank you. I used a downloaded EC file along with the file from post 27. After trying few bin files
                          I was seeing it was updating the bios at 1st boot and it was not working, I thought of plugging the charging lead in
                          as its meant to be plugged in wile updating the bios, this time it updated a few things including the usb-c firmware.
                          it was in manufacturing mode so I could edit all my details.
                          its 100% with a fast boot, Thanks you all.
                            • 21984
                            The bios at post 27 has clean ME firmware and a clean VSS2 store, thats why it worked.
                            • Lurky
                              • Feb 2021
                              • 32
                              • Rwanda
                              #34
                              Hello
                              Woud you please help me with 440 G8 BIOS USER password unlock.
                              450 G8 DAX8QAMB8D0 REV : D
                              SN: 5CD1035QL7
                              Don't post pictures unless asked..
                              • Hachem25
                                • Aug 2021
                                • 52
                                • algeria
                                #35
                                hello i have this hp probook 440 g8 with bios password.
                                SN: 5CD1154ZP3
                                • kros
                                  • Oct 2017
                                  • 18
                                  • IE
                                  #36
                                  Originally posted by Lurky
                                  Hello
                                  SN: 5CD1035QL7
                                  Try it and let me know. Read info in file​
                                  • Hungdunglaptop
                                    • May 2024
                                    • 35
                                    • vietnam
                                    #37
                                    help me unlock bios Hp 440 G8 please .
                                    THANK YOU
                                    MODEL PROBOOK 440 G8
                                    SERIAL 5CD1141VQ7
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12340
                                      #38
                                      THANK YOU
                                      SERIAL 5CD1141VQ7
                                      HP ProBook 440 G8 Notebook PC
                                      CTNumber_6LGXT0A81ENGNN
                                      Serial_5CD1141VQ7
                                      Sku_2Z6G9PA#UUF
                                      Build Id_20WWR3AD301#SUUF#DUUF
                                      Fearture byte_3Y6E6J6S6a7J7M7Q7W7d7m7sawbUbhcAfPguk8m6.y2
                                      • Hungdunglaptop
                                        • May 2024
                                        • 35
                                        • vietnam
                                        #39
                                        Serial_5CD1141VQ7
                                        Sku_2Z6G9PA#UUF
                                        sorry, i sent the wrong SPI ROM file so it's still locked.
                                        this is the EC ROM file
                                        Ps: I did it according to the instructions of member badcaps
                                        • Hachem25
                                          • Aug 2021
                                          • 52
                                          • algeria
                                          #40
                                          someone can help me ?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • CanukTuk
                                            Beginner Tutorial for using RCUnlocker to remove BIOS password?
                                            by CanukTuk
                                            Kinda new to this, so hoping you will all give me a bit of a pass.
                                            I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
                                            I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
                                            Is there a beginner guide anywhere that describes the entire process for doing this?
                                            I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have...
                                            03-24-2024, 02:54 PM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • Soumana Sanou
                                            “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                            by Soumana Sanou
                                            Hello,😇😇😇
                                            I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                            🔧 Model: HP ProBook 11 G2
                                            📦 Serial Number: 8CG72478MY
                                            🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                            🔒 BIOS Status: Locked with password
                                            The laptop is no longer under warranty and HP refused to help me.
                                            I’m looking for a custom SMC.bin file.
                                            I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                            Thanks a lot for your help!🙏🙏🙏...
                                            06-17-2025, 04:04 PM
