Beginner Tutorial for using RCUnlocker to remove BIOS password?
  • CanukTuk
    • Mar 2024
    • 8
    Kinda new to this, so hoping you will all give me a bit of a pass.
    I came to this forum because need to remove the BIOS password on an HP EliteBook 850 G1.
    I understand that I need to dumpt the BIOS to a dump file, process the dump file with RCUnlocker, then write the modified BIN file back to tthe BIOS chip.
    Is there a beginner guide anywhere that describes the entire process for doing this?
    I am reallly in the dark regarding which tool or tools are required to extract the BIOS dump file, then write the modified BIN back to the BIOS chip. The guides I have seen seem to take this step for granted, they start with the BIN file already extracted; and they do not cove the process for updating hte BIOS with the modified BIN file.
    Is there a standard tool, or set of tools, that are the preferred tool(s) for doing this?
    I would appreciate very much if someone could help me with this knowledge, or point me inthe right direction.
    Thank you!
  • mon2
    • 14677
    Post the same request in the dedicated BIOS forum. See above.
    • CanukTuk
      • Mar 2024
      • 8
      Hi, thanks for your advice. Are you referring to the forum called "BIOS requests ONLY!"? I chose to not post this request there because the name seems kinda emphatic about what should be posted there.
      • mon2
        • 14677
        See here (if you have not already):
        RCUnlocker - Badcaps
        • CanukTuk
          • Mar 2024
          • 8
          Yes I saw that post. It describes the features of RCUnlocker.
          What I am interested to know is how to dump the BIOS to a file; and then how to write the modified BIOS file back to the chip.
          My assumption is that RCUnlocker is not used for these steps (am I mistaken?).
          If these steps are not done using RCUnlocker, then what tool or tools are used to do these steps?
          Thanks.
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            The best way would be to dessolder the chip, read it with a programmer ( cheap Ch341a from china should suffice ). Then do the necessary changes to the file, flash it again to the chip, and solder it again to the board.
            There are clips to access the chip while soldered in the mainboard, but they do not work always ( depend on the board and on experience of user ) . So, the easier way is to remove the chip.
            • CanukTuk
              • Mar 2024
              • 8
              Removing the chip is beyond me.
              There is a sepaprate post about doing htis with a HP 850 G1 laptop:
              https://www.badcaps.net/forum/troubl...e3#post1544424
              In that post, there is no mention of removing the BIOS chip.
              Presumably, with this model, the job can be done without removing the chp?
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                When they say "backup your bios first using an spi programmer ", mostly it is implied the chip will have already been removed. The clip thing doesn´t work always, so it is harder to use. Maybe get someone to unsolder it for you ?
                • CanukTuk
                  • Mar 2024
                  • 8
                  Ok thanks for your advice. I was actually looking art ordering gone of those clip things.
                  I will see if i can find someone to unsloder it for me.
                  If I go the unsoldering route, would it be better to just buy an unlocked BIOS chip and have it soldered in, as opposed to extract/modify/rewrite with the original chip? I see they are availalbe on eBay.
                  • ibo
                    • Oct 2019
                    • 105
                    • Turkiye
                    You can always try to read the chip on board without desoldering. make sure you read it twice and compare if the dumps are the same. if they are not the same then you have to take out the chip and read and write it.
                    • tlindi
                      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                      by tlindi
                      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                      >Read BIOS guides, methods, resources and tools
                      Ack
                      >Try the method at BIOS guides, methods, resources and tools before requesting help
                      Ack
                      >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                      python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                      01-30-2025, 04:26 AM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • longmt1990
                      Panasonic Cf-w5 bios password remove
                      by longmt1990
                      Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                      I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                      Please help me remove bios password.
                      Thank you so much
                      07-06-2025, 10:50 PM
                      by Vesko356
                      08-11-2023, 03:27 AM
