bios lenovo thinkpad T14 Gen 2 logo
  • brasil
    • Feb 2019
    • 26
    • Brasil
    Good afternoon, I have a lenovo thinkpad t14 gen 2 board model HT4B0/HP4B0/HT5B1/HP5B1/HT4B2
    NM-D352 REV: 2.0
    that has a company logo when I turn it on, I would like to remove it and have it turn on again with the lenovo logo appearing.
    HERE ARE THE BACKUPS OF THE ORIGINAL FILES, IF ANYONE CAN HELP THANK YOU VERY MUCH.
    • 22215
    Re: bios lenovo thinkpad T14 Gen2 logo
    NM-D352 REV: 2.0
    Have you tried it using the bios update
    How do I remove custom logo from T590? https://www.badcaps.net/forum/showthread.php?t=117918
    • brasil
      • Feb 2019
      • 26
      • Brasil
      not yet, but I'll try and answer you here.
      • brasil
        • Feb 2019
        • 26
        • Brasil
        I tried here and it didn't work
        • volinakis
          • Jan 2021
          • 2875
          • N/A
          it should work, download bios update for your model and CHECK EXTRACT ONLY, NOT UPDATE BIOS! Go to folder where was extracted, usually C:/DRIVERS/FLASH/name-of-bios-version and launch WINUPTP.EXE. It will pop-up a windows saying you have a custom logo and if you want to remove it or not, read what is written.
          • lavie
            • Aug 2015
            • 91
            • southafrica
            please change logo lenovo t14 gen 2 ryzen
            S/N PF3PJZ8Z
              • 22215
              S/N PF3PJZ8Z
              Thread merged, read the posts above
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1356
                • France
                S/N PF3PJZ8Z
                try it, I don't know if it will work
                Edit
                won't work, don't bother testing. is that your logo??
Name:	Sans titre.jpg
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1356
                  • France
                  I tried this
                  Click image for larger version  Name:	image.png Views:	0 Size:	157.8 KB ID:	3575525
                  if not successful with volinakis and SMDFlea solution.
                  I replaced your logo with the original one.
                  Click image for larger version  Name:	replace.png Views:	0 Size:	170.8 KB ID:	3575524
                  to test
                  no certainty that it works
                  @volinakis
                  should it be done with CMD?
                  I saw in another post of yours!
                  https://www.badcaps.net/forum/troubl...om-logo-lenovo
                  • volinakis
                    • Jan 2021
                    • 2875
                    • N/A
                    Originally posted by Maxpower3
                    I tried this
                    to test
                    @volinakis
                    yep, I ran it under cmd as Admin. There is also a "BIOS_LOGO.TXT" in bios update package telling how to replace or remove logo.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1356
                      • France
                      yep,thanks
                      I saw it too
                      I stopped looking for gif which had been replaced by a jpeg with that
                      • lucaszmn
                        by lucaszmn
                        Problem:
                        Initial Findings:
                        • I concluded that the
                        08-12-2025, 03:01 PM
                      • to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                        by to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                        I have opened the laptop and identified the main BIOS chip...
                        10-24-2025, 01:35 AM
                      • 1g0r
                        Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                        by 1g0r
                        First, the data in brief:
                        Manufacturer: Lenovo
                        Model: ThinkPad L15 G3 21C3-0016GE
                        motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                        IC Bios 1: MX77L25650F
                        IC Bios 2​: MX25L25673G
                        EC Chip: NPCX997KAABX
                        So far I've been a silent reader, but now I need your help
                        I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                        I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                        The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                        01-18-2025, 02:39 AM
                      • MaxonDomkrat
                        Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                        by MaxonDomkrat
                        Hi everyone.
                        I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                        07-30-2025, 01:27 PM
                      • akwky
                        by akwky
                        Hi!
                        04-14-2025, 01:56 PM
