Asus ux482e bios?
  • m1ch43lzm
    • Mar 2019
    • 1126
    • Peru
    #61
    Try # 10 https://www.badcaps.net/forum/troubl...21#post1800221
    It's clean BIOS, it should work (no serial), if possible desolder the BIOS chip, program it and solder it back, as your original backup is corrupt (bad read)
    • benten127
      • Sep 2015
      • 7
      • france
      #62
      working !! thanks a lot
      • ingenieroedu
        • May 2023
        • 79
        • Colombia
        #63
        Hello everyone, I'm coming to you with this problem. I've performed a measurement on the laptop's charging system, but I can't find any errors. I've already tried using a new battery, and the problem persists. The problem is that the laptop won't charge the battery. Now all I have to do is test the BIOS. I appreciate any help.
        Motherboard model: UX482EG R2.0
        Serial number: M7N0CV14S228288
        I'm also leaving a background of the QR code.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          #64
          UX482EA
          • ingenieroedu
            • May 2023
            • 79
            • Colombia
            #65
            Originally posted by hoaca388
            UX482EA
            Hi colleague, I appreciate the help, but with this file the laptop won't turn on, only the white charging LED stays on.
            • m1ch43lzm
              • Mar 2019
              • 1126
              • Peru
              #66
              Try BIOS from post # 10 with your DMI inserted
              UX482EA
              S/N M7N0CV14S228288
              DMI 660000h-66FFFFh
              • ingenieroedu
                • May 2023
                • 79
                • Colombia
                #67
                UX482EA
                S/N M7N0CV14S228288
                DMI 660000h-66FFFFh
                thanks this works
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • lrouw84
                  by lrouw84
                  Hi there,
                  01-28-2023, 01:31 PM
