Lenovo s145-14api dump bios
  • madjid911
    • Dec 2016
    • 390
    • France
    HI, my laptop, starts without display, the power button light blinking, i think the bios is corrupted, can you fix my dump? THANKS
    lenovo S145-14API
    motherboard GS440 GS540 NMC511 REV:1.0
    S/N : PF13258A
    MTM : 81UV0031FR
  • madjid911
    • Dec 2016
    • 390
    • France
    Re: Lenovo s145-14api dump bios
    I tried several bios here in the searches but none worked, I did not find the exact model
    • hardware1
      • Sep 2021
      • 2930
      • N/A
      lenovo S145-14API
      S/N : PF13258A
      MTM : 81UV0031FR
      Here's your New BIOS, it's a Virgin BIOS from Lenovo with your DMI.
      all donations are welcome,
        • 20914
        DMI 1000 - 2FFF (0x01000 - 0x02FFF)
        S145-14API Type 81UV .Bios Version: BUCN33WW
        Anyone can add their own DMI easily using the bios from post #3 and your own backup with the attached CopyDMI script.
        Easy Guide: Copy DMI info easily with Hex editing software and Macro script -> https://www.badcaps.net/forum/showthread.php?p=1214739
        • madjid911
          • Dec 2016
          • 390
          • France
          it didn't work, i think the processor is dead
          THANKS
          • madjid911
            • Dec 2016
            • 390
            • France
            Thanks for the link, I can try to do it myself now.
            • Azrael29
              • Mar 2023
              • 3
              • France
              Hello, I have exactly the same problem as madjid911, I tested several bios on the forum, without success.
              Is that someone could check my backup? I am not sure what is correct.
              I tested this solution with my backup, but it doesn't work.
              Lenovo S145-14API
              S/N : PF1DBX16
              MTM : 81UV0031FR
              Thanking you in advance.
              • peste
                • Dec 2016
                • 12811
                • ROMANIA
                Lenovo S145-14API
                S/N : PF1DBX16
                MTM : 81UV0031FR
                you have everything you need at post #62, if it doesn't work you have another problem, or you don't write the bios correctly..
                https://www.badcaps.net/forum/showth...5-14api&page=4
                • Azrael29
                  • Mar 2023
                  • 3
                  • France
                  Yes, the problem is apparently elsewhere, I got the boot page once flashed with the bios you gave me.
                  Really amazing to have the same failure, the same month and the same year.
                  I would have a doubt about the welded ram? To see, I will continue my investigation.
                  Thanks for your answer.
                  • agusguffa
                    • Oct 2024
                    • argentina
                    Good evening, I have a Lenovo IdeaPad S145-14API and my PC has completely crashed (the Lenovo app downloaded and installed a BIOS) to the point where the screen went black. I tried to download the BIOS .exe from the official website and extract the .cap, put it on a formatted USB, then press fn + r and the disk light flashes without reading the USB. I don't have the old BIOS or anything or I don't know how to access it. Thanks.
                    PS: I'm using a translator, sorry if there are errors.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11738
                      You have to buy an SPI programmer, there are many types, many prices.
                      For example: CH341A, this is the cheapest type.
                      https://www.youtube.com/results?sear...mer+how+to+use
                      Once you have the dump, post it here with the serial number.
                      • Ahmad Mukhtiar
                        • Feb 2025
                        • 3
                        • Pakistan
                        Hi there. Got this issue in 2025. how did you fix it? You have the same model as me? S145 14 API. I updated my bios from Lenovo site and after update it restarted and it's black screen now. No power led blinking, just a black screen and fans spin after some time. I tried doing hard reset and CMOS and everything but nothing worked. Can you tell me what you did to fix it?
                        • Ahmad Mukhtiar
                          • Feb 2025
                          • 3
                          • Pakistan
                          Also I don't know how to use this site. I thing I'm messing up the comments
                          • Ahmad Mukhtiar
                            • Feb 2025
                            • 3
                            • Pakistan
                            Hey did you fix it 😭? I did the same things you did and having this issue. Also I have done all the fixes you mentioned it didn't fix it.
                            Did you fix it?
                            • Pedro Ramírez
                              • Jul 2024
                              • 21
                              • Chile
                              Lenovo GS440 & GS540
                              Hello, could you help me with the BIOS update for my Lenovo Ideapad S145-14API?
                              Model Name: 81UV
                              S/N: PF3R8NS7
                              MTM: 81UV00ATCL
                              It turns on without video and the LED is blinking.
                              I've attached a BIOS backup.
                                • 20914
                                Model Name: 81UV
                                S/N: PF3R8NS7
                                MTM: 81UV00ATCL
                                Your backup isn`t good, make another one
                                • Pedro Ramírez
                                  • Jul 2024
                                  • 21
                                  • Chile
                                  Dear friend, I'm sorry. I may have attached the wrong backup or misread it. Here's the BIOS again. I'd be very grateful if you could help me recover it. 🙏
                                  • peste
                                    • Dec 2016
                                    • 12811
                                    • ROMANIA
                                    you have everything you need at post #62..
                                    https://www.badcaps.net/forum/troubl...5-14api&page=4
                                    • AHmad_Salal
                                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                      by AHmad_Salal
                                      Hello all,
                                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                      11-28-2023, 05:28 AM
                                    • hyperwood
                                      [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                                      by hyperwood
                                      I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                                      The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                                      I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                                      ✅ What I need:
                                      • A working 2MB BIOS dump
                                      • Matching NM-E471 Rev. 2.0, e.g. JY575
                                      06-25-2025, 02:28 PM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • Joluvillas
                                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                      by Joluvillas
                                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                      06-18-2024, 10:35 PM
                                    • Captaincrap420
                                      Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
                                      by Captaincrap420
                                      Hi, I hope this is the right place to post this. This is my first post on this forum.
                                      A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
                                      This bios dump is straight from the chip, nothing has been...
                                      11-29-2024, 05:40 PM
