Need Clean ME Bios Dell 7320 LA-K371P Rev.3.0
 Hello. Please help me rebuild BIOS. It won't power on.
 SVT: 269CXD3Attached FilesComment
 try and feedbackAttached FilesComment
 please help me clean this bios, it boots up with TMP error. service tag: 3Y6F6D3Attached FilesComment
 Thank you. It still reports TPM error, I attached the wrong bios. this is the error biosAttached FilesComment
 You MUST NOT:- Bump your thread or post more than once every 48 hours. If you do so
 you will receive an infraction
 Hello I have Dell Latitude 7320 Detachable, Service Tag BTPN6M3, I removed password and computrace but now its not detecting NVME SSD. Can someone help to make it detect SSD.
 ThanksAttached FilesComment
 [QUOTE=Bios Cracker;n3691989]
 Try and Update.[/QUOTE
 Hello bro try this file
 GOOD AFTERNOON TO YOU ALL PLEASE I NEED HELP WITH MY DELL LATITUDE 7430 BIOS BIN MINE IS BLINKING WHITE AND ORANGE LIGHT.
 ST/N 18S8QN3
 BOARD NO/ GDC31 LA K371P REV 2.0 (A01)
 BELOW IS THE BACK UP BIN FILEAttached FilesComment
 LBTT1121 is right ,the motherboard is not for the 7430 .The service tag in your bios is 77J0C93 and the model is Latitude 7420.Comment
 Hi everyone, i need password cleared from this bios...
							Channel: BIOS Requests ONLY!
			by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...-
 04-23-2025, 04:30 PM
			by capoplaysHey everyone,
 I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
 The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
 When I check the BIOS using the F12 menu Flash...-
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
			by SathsulSo, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
 The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
 However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...-
- Loading...
