Need Clean ME bios Asus A409MA
  • cyngo
    • Jun 2015
    • 216
    • Indonesia
    The problem is when the laptop sleep, the laptop doesn't want to wake up
    I tried flashing the bios from official website but it didn't work
    thanks in advance
    original bios
  • Lisa Su
    Badcaps
    • Apr 2021
    • 213
    • Taiwan
    Re: Need Clean ME bios Asus A409MA
    Try this
    • cyngo
      • Jun 2015
      • 216
      • Indonesia
      Originally posted by Lisa Su
      Try this
      is this a file from the official web? I have tried it as I have previously informed.
      • Lisa Su
        Badcaps
        • Apr 2021
        • 213
        • Taiwan
        No. It's an engineering BIOS (Clean ME, No DMI data) used internally by ASUS.
        • cyngo
          • Jun 2015
          • 216
          • Indonesia
          yes, but this bios is the same as the one i got from asus web & i have tried it
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
