bios repair FL490/FL590 NM-B931
  • azemar
    • Nov 2022
    • 46
    • France
    Hello can someone fix me the bios of my lenovo l590 MB:FL490/FL590 NM-B931
    I extracted the bios but I don't think it contains much info.
    Thank you
    IC: W25Q80JVSIQ
  • hoaca388
    Badcaps
    • Jan 2022
    • 12433
    Re: bios repair FL490/FL590 NM-B931
    W25Q80JVSIQ isn't bios chip. Find an other chip and post your serial number more.
    • azemar
      • Nov 2022
      • 46
      • France
      yes sorry I got the wrong chip it's the w25q256JV I extracted the bios here it is for the serial number it's PF-1CRUFK
      • Elvirus
        • Dec 2022
        • 13
        • Deutschland
        Try one of this if it is as you wrote ThinkPad L590 (type 20Q7, 20Q8) FL490F L590 NM-B931 Bios Bin
        Because of yoyr Serial Number its not a L490
        • Elvirus
          • Dec 2022
          • 13
          • Deutschland
          I hope hoaca388 could double check it because i am new at this
          • azemar
            • Nov 2022
            • 46
            • France
            I tried both and I have the power light coming on then the capslock blinks once and it goes out
            • hoaca388
              Badcaps
              • Jan 2022
              • 12433
              ThinkPad L590 - Type 20Q7
              • azemar
                • Nov 2022
                • 46
                • France
                thank you i will test
                • azemar
                  • Nov 2022
                  • 46
                  • France
                  returned to the starting point capslock turn on and power, CPU which heats up slightly and black screen.
                  the main voltages are ok 5v 3.3v 20v 12v (battery charge)
                  • bbanana
                    Father Land
                    • Oct 2021
                    • 164
                    • Vietnam
                    try
                    • azemar
                      • Nov 2022
                      • 46
                      • France
                      Originally posted by bbanana
                      try
                      same no change 🫤
                      • Elvirus
                        • Dec 2022
                        • 13
                        • Deutschland
                        try this
                        • Elvirus
                          • Dec 2022
                          • 13
                          • Deutschland
                          what happens with your original Bios? is it the same?
                          • azemar
                            • Nov 2022
                            • 46
                            • France
                            yes the same thing, I have not yet tested your bios I will do it tomorrow
                            • Elvirus
                              • Dec 2022
                              • 13
                              • Deutschland
                              hope it works
                              • azemar
                                • Nov 2022
                                • 46
                                • France
                                try this
                                Hello
                                I just put your bios, I only have the power light on but still black screen. the cpu does not heat up
                                • azemar
                                  • Nov 2022
                                  • 46
                                  • France
                                  hoaca388 do you have an idea of the problem?
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12433
                                    My idea is that you shouldn't look for bios solutions anymore, go looking for hardware problems.
                                    • azemar
                                      • Nov 2022
                                      • 46
                                      • France
                                      ok but I don't know where to look for hardware
                                      • Elvirus
                                        • Dec 2022
                                        • 13
                                        • Deutschland
                                        Azemar did you connect your laptop to an external monitor if the capslock is on i think its actually booting but noo screen
                                        i think hoaca388 is right
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • bschwand
                                          ASUS N550JK laptop reboots after 30 minute, BIOS extracted invalid...
                                          by bschwand
                                          as subject line says, I have a laptop that reboots after 30 minutes. Investigation leads me to believe that is due to intel ME as it happens everytime after 30 minute from boot, it just turns off, no overheating, nothing weird.
                                          I found a lot of information about cleaning ME like this https://winraid.level1techs.com/t/gu...lization/31277 and this https://github.com/corna/me_cleaner
                                          Anyway, first step is to dump the bios. I found the Winbond W25Q64FV chip on the motherboard, dumped it with flashrom over...
                                          05-22-2024, 02:48 AM
