bios repair FL490/FL590 NM-B931
  • cornelus1978
    • Mar 2025
    • 8
    #61
    THe serial, model, motherboard number are in the pictures posted.
    as history i can say, buyed on an auction, no display posted, i followed the corupted bios situation, flashed few bin's from this forum, and the board only booted with that posted days ago who has missing ME, and now with Volinakis file (outimage.bin).
    the battery problem was on both bioses, freeze on trying to boot with battrery attached, work normaly without battery
    hope i explained good, and sorry if my english is not so good
    thank U
    • Lovro25
      • Jan 2023
      • 22
      • Croatia
      #62
      Hello all,
      Can someone help with this bios? The laptop turns on but shows no picture.
      Lenovo Thinkpad L590
      SN: PF13NJ4K​
      • zuu327
        suhailmohd
        • Jun 2024
        • 29
        • UAE
        #63
        THINKPAD L590 S/N ;PF-26FHJ2
        NM-B931 REV 1.0
        NO DISPLAY PLZ FIX THIS FILE ANY ONE CAN HELP ME
        • ErParucca
          • Jun 2025
          • 45
          • FR
          • Technology, photography, singing
          #64
          Originally posted by SMDFlea
          Copy it from another bios to yours using a hex editor. 45 56 53 41
          I bought a replacement motherboard but only a NOK was available. Could you please be more specific about which portion of the BIOS has to be copied between the systems?
          Thanks!
            • 24335
            Thanks!
            Only the windows key is in the bios, the serial number and other DMI in the EC. What are you wanting to copy, the key ,DMI or both. Do you have the backup from both boards.
            • ErParucca
              • Jun 2025
              • 45
              • FR
              #66
              apologies. Let me rephrase that: I had a HW failure on a motherboard. I bought a new one but it's NOK (no windows key) as the others were 10x more expensive. I'd would like to move the windows license from the old MB to the new one. Not for me (I know MAS and plenty other tools to activate windows) but just in case I will sell my laptop in the future, to offer a seamless experience to the possible future buyer.
              Thanks!
                • 24335
                Thanks!
                If you have a bios programmer and know how to use a hex editor it`s fairly easy to copy it from your old board bios to the new one. Post both your bios if you`re unsure and i`ll do it for you.
                • ErParucca
                  • Jun 2025
                  • 45
                  • FR
                  #68
                  I do but I didn't get at which offset of the content I have to make the edit: you wrote "45 56 53 41": what does that refer to? Thx!
                    • 24335
                    EVSA ,it`s been mentioned before on the forum. The key is at the end of one of the EVSA areas. On some models after a bios update the key can be at a slightly different offset. You can search for the key by looking for hex 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00 .It isn`t just the key you need to copy, its the other part around it as well , you`ll see what i mean
                    • ErParucca
                      • Jun 2025
                      • 45
                      • FR
                      #70
                      EVSA ,it`s been mentioned before on the forum. The key is at the end of one of the EVSA areas. On some models after a bios update the key can be at a slightly different offset. You can search for the key by looking for hex 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00 .It isn`t just the key you need to copy, its the RSA part as well , you`ll see what i mean
                      apologies, I must have missed that post/message during my search; thanks for the reference, now I know what to search for/write
                      • ErParucca
                        • Jun 2025
                        • 45
                        • FR
                        #71
                        damn, the single BIOS chip on these machines is a 512Mb/64MB one and it's a WSOP: it requires 10+ minutes of applying pressure to read it and I fear how long it will take to write is there any faster alternative to CH341A? Or at least something than can do read->verify->verify->re-read if not ok->next block rather than reading all only to realize later that there was an error?
                        • Sparo
                          Sparo commented
                          Editing a comment
                          Get a better programmer for faster reading > Section 1.1.1. https://www.badcaps.net/forum/troubl...=2#post1622421
                          Also many prefer soldering wires beteen chip and adapter instead of applying pressure with the probe. Maybe that will fix your 10+ minute issue if you don’t want to upgrade?
                          But the best way IMO is to unsolder the chip. It’s necessary for many newer models anyway because you usually can’t read/write them in-circuit unless you cut the Vcc track
                      • ErParucca
                        • Jun 2025
                        • 45
                        • FR
                        #72
                        Laziness makes us smart
                        • Sparo
                          Sparo commented
                          Editing a comment
                          I been there x) but like I said this "hold" won’t work on newer models that don’t allow in-circuit programming. The only way is to isolate the chip AKA unsolder / cut Vcc
                      • ErParucca
                        • Jun 2025
                        • 45
                        • FR
                        #73
                        Thanks, I was indeed able to find the area thanks to your direction. Problem being that the hex pattern you provided only seems to exist when a license is installed: there's no trace of it in the BIOS' content that doesn't have a license so I know what to paste following up your example but not where to paste it
                        For those coming here for similar reasons: EVSA is often considered es a typo by search engines because it's a rare acronym compared to others (for example EVGA); if you want to search more about it, better to search for "EFI Variable Storage Area".
                        • tracker1
                          • Jul 2017
                          • 139
                          • romania
                          • Laptop Bios & Schematic
                          #74
                          Lenovo L590 power on no picture
                          Need help to fix bios pls
                          Type 20LW-000VGE
                          MB NM-B931 REV 1.0
                          SN PF-154AQ6
                          • MegaGlobal
                            • May 2026
                            • CENTRAL
                            #75
                            Lenovo L490 20Q6 SN/ PF29MXCE,
                            with my original bios, it cant display, i already try to clean but still same,
                            i tried bios #47 working but DMI missing. i tried to writing dmi, eror because eeprom locked R/W.
                            anyone can help or add dmi from orig to bios #47?
                            here attc my bios and bios #47
                            thanks for help
                            • Sparo
                              Quicksilver
                              • Jan 2022
                              • 3755
                              • M\A
                              • Anime, Edge Computing, Football, Snooker
                              #76
                              thanks for help
                              Hi try this BIOS file
                              Lenovo L490 (type 20Q5, 20Q6) Laptops (ThinkPad) - Type 20Q6
                              Machine Type Model 20Q6S1VS00
                              BIOS Version 1.21 (R0ZET43W)
                              WinKey/12C0000-12CFFFF
                              Enjoying our forum? Subscribe to unlock extra perks!
                              >> Upgrade here <<
                              πŸš€πŸ’¬πŸš€
                              • macabook
                                πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • TopPop
                                Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
                                by TopPop
                                Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
                                I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
                                12-14-2025, 09:40 PM
                              • Deniz
                                IdeaPad Gaming 3 16IAH7 BIOS Issue / GPU Not Detected
                                by Deniz
                                Bu: https://pcsupport.lenovo.com/tr/tr/p...065tx/mp2br7d9
                                I have a Lenovo IdeaPad Gaming 3 16IAH7. When the device first arrived, there was no display at all.
                                I had the BIOS cleaned, but the issue was not resolved and there was still no image.
                                Later, I flashed a different BIOS dump from the same model. With this BIOS, the device boots and display works, but the GPU is not detected in the BIOS (RTX 3060 is missing).
                                After that, I tried to update the...
                                01-27-2026, 06:56 AM
                              • zlr8r
                                looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                by zlr8r
                                looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                cheers
                                Dell Inspiron 17 (7786) Laptop
                                Service Tag: 5J0NHT2
                                Bios: 1.9.0
                                MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                Attached;
                                1. My saved bios using a programmer
                                2. Dells Bios updater .exe (v1.16)
                                3. Dells Bios recovery file
                                4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                5. Image of ME...
                                12-18-2023, 03:08 PM
                              • istvanszasz99
                                Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                by istvanszasz99
                                Product ID: RZ09-0421
                                Motherboard: CH580
                                Bios File Size: 32,768 KB
                                Dear Forum Readers!
                                !!! MY RAZER BLADE...
                                11-24-2025, 05:52 PM
